Overclocking Help needed with Overclocking i7-930
Discussion in 'Hardware' started by happyhammer7, 22 Apr 2011.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    I am currently running the following system -
    i7-930
    noctua nh-d14 CPU Cooler
    GA-X58A-UD3R motherboard
    3x2GB Corsair XM3 RAM (timings 9-9-9-24)
    This is my first venture into overclocking so I need some advice. I have done some research online and used some other templates to get me started. I have overclocked currently to 3.6Ghz and stress tested using Prime95 for 10 hours and 20 passes of Linx and it seems very stable. I have been gaming on it as well with absolutely no problems.
    Temps in Prime95 were about 60-61C load so I don't want to go to much higher than that. My aim is to reach 4Ghz with minimum voltage/heat.
    Here are my current settings
    Advanced CPU Features:
    CPU Clock Ratio ................................ [21x]
    Intel(R) Turbo Boost Tech .................. [Enabled] (3.6Ghz)
    CPU Cores Enabled ............................ [All]
    CPU Multi Threading .......................... [Enabled]
    CPU Enhanced Halt (C1E) ................... [Enabled]
    C3/C6/C7 State Support .................... [Enabled]
    CPU Thermal Monitor ......................... [Enabled]
    CPU EIST Function ............................ [Enabled]
    Virtualization Technology ................... [Enabled]
    Bi-Directional PROCHOT ..................... [Enabled]
    Uncore& QPI Features:
    QPI Link Speed .............................. x36
    Uncore Frequency .......................... x20
    Isonchronous Frequency ..................[Enabled]
    Standard Clock Control:
    Base Clock (BCLK) Control ................ [Enabled]
    BCLK Frequency (MHz) .....................160
    PCI Express Frequency (MHz) ........... [100]
    C.I.A.2 [Disabled]
    Advanced Clock Control:
    CPU Clock Drive ..............................[700mV]
    PCI Express Clock Drive ................... [700mV]
    CPU Clock Skew ............................. [0ps]
    IOH Clock Skew ............................. [0ps]
    Advanced DRAM Features:
    Performance Enhance ...................... [Standard]
    Extreme Memory Profile (X.M.P) ......... [Disabled]
    System Memory Multiplier (SPD) ........ [10]
    DRAM Timing Selectable (SPD) .......... [Expert]
    Channel A + B + C
    Channel A Timing Settings:
    ##Channel A Standard Timing Control##
    CAS Latency Time ......................9
    tRCD .......................................9
    tRP .........................................9
    tRAS .......................................24
    ##Channel A Advanced Timing Control
    tRC ........................................ Auto(27)
    tRRD .......................................Auto(4)
    tWTR ...................................... Auto(4)
    tWR ........................................Auto(8)
    tWTP .......................................Auto(19)
    tWL ........................................Auto(7)
    tRFC .......................................Auto (60)
    tRTP .......................................Auto(4)
    tFAW ......................................Auto(20)
    Command Rate (CMD) ................1
    ##Channel A Misc Timing Control##
    Round Trip Latency ...................Auto(59)
    Advanced Voltage Control:
    CPU
    Load Line Calibration .................[Standard]
    CPU Vcore ...............................1.23750V (1.20000v)
    QPI/VTT Voltage 1.150v ............1.175v (1.175v)
    CPU PLL 1.800v .......................Auto(1.800v)
    MCH/ICH
    PCIE 1.500v ...........................Auto(1.500v)
    QPI PLL 1.100v .......................Auto(1.10v)
    IOH Core 1.100v .....................Auto(1.10)
    ICH I/O 1.500v .......................Auto(1.50)
    ICH Core 1.1v ........................Auto(1.10)
    DRAM
    DRAM Voltage 1.500v ..............1.640v
    DRAM Termination 0.750v [AUTO]
    Ch-A Data VRef. 0.750v [AUTO]
    Ch-B Data VRef. 0.750v [AUTO]
    Ch-C Data VRef. 0.750v [AUTO]
    Ch-A Address VRef. 0.750v [AUTO]
    Ch-B Address VRef. 0.750v [AUTO]
    Ch-C Address VRef. 0.750v [AUTO]
    Where do I go from here? I want to do it gradually to reach 4Ghz and will carry out regular stress testing. Any advice on what settings to change/tweek?
    Thanks guys :rock:
  2. Instagib
    Instagib Minimodder
    12 Mar 2010
    You say you don't want to go much past 60-61 degrees? If you want to hit 4ghz, you're gonna have to bite the bullet as you'll be very lucky to keep it under 75-80 degrees. 85 shouldn't be frowned on at that speed.
  3. happyhammer7
    19 Oct 2009
    Fair enough mate. I can always downclock it after if I wish to. What do you think my next steps will be?
  4. Instagib
    Instagib Minimodder
    12 Mar 2010
    Okay, first off, take speed step off.
    Bump the BCLK count to 191
    CPU clock drive to 900mv
    Load line calibration set to it's highest (is that extreme?)
    CPU Vcore 1.3
    QPI/VTT to 1.3
    QPI PLL to 1.3
    Check the Mem speed at that point; it'll be running out of spec.
    The QPI link speed will need tweaking, but i can't recall off the top of my head...
    That'll be around the 4Ghz mark. Check the voltages, these are only rough; you may need more or less.
  5. Instagib
    Instagib Minimodder
    12 Mar 2010
    If the system has issues (not posting/not loading windows/not stable) It'll be the QPI link speed. You want to set the ratio to twice the speed of the memory. Approx. I think.
  6. happyhammer7
    19 Oct 2009
    I dropped vCore and QPI slightly and link speed is just under double my memory speed.
    Testing stability now with Linx and temps are hovering around 77C. Is this temperature safe?
  7. Instagib
    Instagib Minimodder
    12 Mar 2010
    Yep, that's a brilliant temp. These chips cut out at 100 to prevent damage. Anything below is fair game.
    Expect to spend the whole bankholiday weekend tweaking now. You sir, have just been bitten by the overclocking bug.
  8. happyhammer7
    19 Oct 2009
    You are spot on there mate. Just at 3.8 Ghz at the moment, and so far, it's stable after 10 passes of linX. My temps are at 70C but I need to reapply the thermal paste as I think I put a tiny bit too much on. Will then gradually reduce voltages to as low as possible. Will be replacing all the fans in my Corsair 650D to Noctua fans as well.
    As I am now getting into overclocking, it has got me thinking about watercooling.
    There is no doubt, overclocking is definately a bug.
  9. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    How do you guys 'gradually' reduce voltage if you have to spend hours running a bench? I mean does the system lock up as soon as too little or too much voltage is used? I'm reluctant to tinker with my settings as I don't want to subtract 0.5 something or other, run a 5 hour stress test, have it fail, try again etc etc etc.
  10. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    that is generally the only way you can do it safely, once you get to know your system, how good your chip is, your board, cooling etc, it becomes relatively easy I think :)
  11. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    my 950 for example, i know that it requires a big voltage jump to hit 4ghz but will sit quite happily at 3.8 on a much lower voltage
  12. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    My 920 sits pretty at 1.2V for 3.8GHz. My old 930 was an abysmal overclocker and needed 1.45V for 4GHz.
  13. Ljs
    Ljs Modder
    4 Sep 2009
    At the risk of getting shouted at, I use IBT (IntelBurn Test). A 5 minute run seems to weed out problems that take hours in Prime. It certainly seems push the CPU more as temperatures to get a little hotter.
    So even if you used that as a preliminary test, and then sit what you think maybe be a more final setting in Prime for 12 hours you have won a whole lot of time.
  14. GeorgeStorm
    16 Dec 2008
    At the risk of getting shouted at, the only testing I do is F@H, or if I'm benching, then obviously whatever bench I'm doing at the time.
    Just OC it, use it, if it crashes, up voltages/reduce speed, have another go.
    Don't see the point in stressing it for the sake of stressing it.
  15. Toploaded
    Toploaded What's a Dremel?
    28 Mar 2010
    I'm considering doing my first ever overclock using the same CPU, but I doubt I'll try and reach 4Ghz. Might just see if I can get a nice stable 3.6 and be happy with that.
  16. [PUNK] crompers
    20 May 2008
    IBT is a great way of quickly OCing, although i have had OC's pass IBT and fail a long Prime test.
  17. GregTheRotter
    9 Aug 2008
    Would you mind sharing your settings for your oc? Seeing as we have pretty much the same board (P6T vs P6T Deluxe would be the same in this respect?) ? I am running 3.8ghz with cpu voltage of 1.25. Would you say there'd be much temp difference between 1.25 and 1.2V?
  18. GeorgeStorm
    16 Dec 2008
    Just try reducing the vcore a bit at a time, there are no blanket settings. Everyones setup is different, so just have a play!.
    I'm running 4.2 @ 1.28v you may need 1.4v to get there, it's far better to just learn your own system.
  19. thetrashcanman
    18 Nov 2010
    this! you can get a rough guide from others, but because of the difference between chips, you could have a massive voltage difference to get to say 4Ghz, my 950 needs 1.39v to be stable @4ghz
  20. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I suppose if you're a -real- idiot (IE: Me.) : You can use an In-OS Overclocking application to gently step the voltage back, that doesn't always show up voltage deficiencies, however, This thing, while being an AMD, will bench at 1.525, yet refuses to start with anything less that 1.575. So your Mileage will vary between chips, Just experiment and tweak as you go along.
    It's not hard to work out a knack for it, especially if it's a motherboard you're familiar with.
