Networks Help needed with pcie wireless card
Discussion in 'Hardware' started by CrapBag, 10 Jul 2020.
  1. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
    I have just finished setting up the old pc for my brother in law and have been doing so using a really long ethernet cable to my router for trouble free installing.
    I'm delivering this early tomorrow morning and only now did I think to test the Wi-Fi card that's in it and yup I cant get it to work.
    It can see my neighbours plusnet Wi-Fi network through the walls but cant see my sky network which is just feet away.
    Think I have a sky hub and the card is 802.11n and I think my security is WPA2 PSK.
    Any ideas?
    The card is a railink wireless wan card ver 2 I believe.
  2. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    You on genuine drivers crappy or did you let MS pull their own down
  3. CrapBag
    17 Jul 2008
    Let MS do there stuff then downloaded and tried to install drivers I found but MS told me theirs were newer.
  4. RedFlames
    23 Apr 2009
    2.4GHz card trying to connect to a 5GHz network?
  5. CrapBag
    17 Jul 2008
    Got 2 separate as my lad uses the 5ghz for his phone games or his switch, can't remember.
  6. RedFlames
    23 Apr 2009
    Some routers use different SSIDs for the different bands... some use the same one for both.
    modd1uk likes this.
  7. CrapBag
    17 Jul 2008
    This one does exactly that but I set it up manually for 2.5ghz and 5ghz to see if it would stop the frequent WiFi drop out but alas it didn't and it's just sky's crappy hub.
  8. CrapBag
    17 Jul 2008
    Now edge refuses to display most websites I try, managed to download chrome and that's doing the same.
