Memory Help needed
Discussion in 'Hardware' started by hirezo, 29 Sep 2009.
  1. hirezo
    hirezo Minimodder
    27 Jul 2009
    im building my first rig. my motherboard can take dual ddr3 ram, so i'm looking to buy 4gb of ram for about £100
    first off does anyone know what brands are good? links would be helpful.
    i found this on the net, anyone know if they're any good?
    http://www.play.com/PC/PCs/4-/85821...Computer-Dual-Channel-Memory-Kit/Product.html
    oooooh, almost forgot the ram can only be a max of 1600mhz
    _____________________
    TIA! :D
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    What motherboard you going to be using mate?
    hirezo likes this.
  3. Krikkit
    21 Jan 2003
    Have a look at the buyer's guide - that's what it's there for. :thumb:
  4. hirezo
    hirezo Minimodder
    27 Jul 2009
  5. Kyocera
    Kyocera The Garden of Evil
    9 Sep 2009
    Asking only for RAM or are there other questions?
    so that we don't make out an endless thread...of discussion..
  6. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
  7. hirezo
    hirezo Minimodder
    27 Jul 2009
  8. smc8788
    smc8788 Multimodder
    23 Apr 2009
  9. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    This would be my choice.
  10. hirezo
    hirezo Minimodder
    27 Jul 2009
    awesome...thanks for the help guys! :)
  11. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i usually just buy whichever ram has the prettiest heatspreaders. it's worked out well for me so far.
  12. hirezo
    hirezo Minimodder
    27 Jul 2009
    loool
  13. Tyr
    Tyr Minimodder
    7 Jun 2006
    Oooh, SHINY!!!!! :hip:
    RAM speed generally makes less than 1% difference in performance once you have the right amount. As stated earlier, for overclocking you do want good ram but otherwise it doesn't matter much at all.
    If you do buy more expensive RAM it isn't guaranteed at that speed on all motherboards anyway as I sadly seem to be discovering.
  14. hirezo
    hirezo Minimodder
    27 Jul 2009
    will take that to note when i buy my ram :)
  15. hirezo
    hirezo Minimodder
    27 Jul 2009
    thanks for the help guys, bought my ram today! woop!
