Hi I'm not sure if this should go here or in hardware but I'LL post it here in the hopes that someone can help. I'm due to be having surgery on my right shoulder and due to several factors there's a good chance I won't be able to use my right arm at all for about 8 to 12 weeks, But I like gaming I've got Belkin Speedpad n50 (old I know but still usable) but I need a way to play rust one handed (pve not pvp for the moment) does anyone know of a device that I can use with just my left hand that would let me play a FPS. Either a name of the device a link anything would be helpful I'm due the surgery May 9th so I've got until about may 1st to find something and order it. any help would be appreciated as I'm dreading 8-12 weeks of no gaming.
Whilst not directly designed for it. The only thing I can think of is the Steam Controller which in theory is re-mappable to any configuration you think might work e.g. left hand in a standard controller placement having access to a touchpad, joystick, bumper, trigger, and back paddle, or perched on top able to access both touchpads, joystick, ABXY buttons
You can get USB foot pedal switches if you just need too control a few actions: https://www.amazon.co.uk/s?k=foot+pedal+switch+usb
not got any personal experience, but oneswitch.org.uk list a bunch of one-handed controllers and some links to alternatives.
Thanks for the replies guys I've looked into the various options and have decided that none of them will be suitable either due to the price or due to not having enough controls so I'm going to just give fps gaming a miss for a couple of months. I'll catch up on my reading or something instead.
Not cheap, but the left half of a Keymouse would probably work for a decent number of keys + a zero-order (rather then first-order like a thumbstick) input.
