Networks help needed
Discussion in 'Hardware' started by ocha, 29 May 2002.
  1. ocha
    ocha Minimodder
    29 Dec 2001
    ok guys heres the deal, im trying to set a home LAN up, ive installed both NICs and have a netgear FS105 switch that im connecting them together by. I have XP pro on my machine and ME on the downstairs machine. So why can they not see each other when i have run the wizard to set it all up. Any ideas are helpful.
    Lm
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    have you set up the IP adresses and the workgroup??
    on your machine (main machine/XP machine) set the ip adress under tcp/ip settings to 192.168.0.1 and the other machine to 192.168.0.2....once that is done try pinging each other across the network by going into dos and typing ping x.x.x.x....
    if you cant get to see each other that way i would recommend checking the drivers for the nic cards....
    also upgrading the me machine to win2k or to xp would make i a lot easier....
    hope this helps....
  3. Fatboy
    Fatboy Bored
    8 Oct 2001
    right click on my network places in ME and look under thwe workgroup and check it is the same , check youn got the right cable, check the switch is on , bind tcp/ip ipx/spx and netbeui protocols to the network cards, enable netbios in the protocol properties, if nothing slam head on floof repeatedly. :D
  4. felix the cat
    11 Jan 2002
    im sure that will help fatboy...
    btw, you wont need ipx unless you plan on playing ra2 over the network....
  5. Fatboy
    Fatboy Bored
    8 Oct 2001
    quite a few games use ipx, better to have it ready than faff around later.
  6. felix the cat
    11 Jan 2002
    if you say so...makes it simpler without it...
  7. ocha
    ocha Minimodder
    29 Dec 2001
    Ok well is that just for ME or should i do all the in XP as well, also how do i bind it to the NIC card?? Workgroup is the same, should have the right cable, anyway of tellin by looking at it? switch is on and there is activity when i ping or it logs on but there is you still cant see the other comp. what will net BIOS do btw?
    Thanks for the help hopefully ill get this LAN running
    Lm
  8. felix the cat
    11 Jan 2002
    when you ping the other computer what does it say??
    why dont u upgrade the other computer to winxp as it would make i a lot easier for yourself....
  9. ocha
    ocha Minimodder
    29 Dec 2001
    ok well when i ping it says, either
    Request timed out or
    host unreachable
    Basicly because my lovely little errr XP cd has a tiny scrath and when i try to upgrade the PC it says, something about cleaning the disk, tis very annoying i have tried 3 times. got any other suggeastions
  10. felix the cat
    11 Jan 2002
    make a copy of the xp cd...
    cause it says that when you ping the computers it could mean a couple of things:
    a) you havent set the ip adresses up properly
    b) your cable/s dont work
    c) your hub/switch dont work
    check the ips first...then test the cables with some that u know that work, ie test em on a mates lan or at work or somethin...
  11. ocha
    ocha Minimodder
    29 Dec 2001
    ok my Ip addresses are 192.168.0.2 for ME machine,
    and 192.168.0.1 for the XP machine
    ill test the cables and the switch soon but i know one cable works for deffinate
  12. Cruelinios
    Cruelinios EvE Addict
    21 Jan 2002
    I recently ran XP Pro and I found the network setup wizard v. annoying. I couldnt get my 2k machine to see my XP machine, but I figured out the problem, heres a checklist of things to check...
    Make sure that your workgroups are the same.
    Check that the XP built in firewall is not on, if it is, turn it off and get Tiny Personal Firewall.
    Put IPX on anyway, if your like me and like the regular Counter-Strike game over a network and one of your mates has tcp/ip problems, then IPX is always handy to have, and there is no considerable speed difference with the HL engine :D
    Make sure your network card is installed properly, check the device manager and make sure there isnt an error with it
    Hope that helps
  13. ocha
    ocha Minimodder
    29 Dec 2001
    ok that is all fine but still wont work this is annoying me now.:grr: hmmm ave to have a think about this one
  14. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    you dont even need the switch if its just two computers just use a rollover cable and plug it into the two nic's and your good to go, set the IP's AND CHECK THE SUBNETMASK they need to be the same!!!!!!
    if you do use the hub/switch then you need 2 straight through cabels, these are what you usually get, you can tell by looking at the clear ends if both plugs have the colors wired in the same order in the same direction your good to go.
    make sure your conections are seated properly if the cabels are loose then that can be problematic. workgroups need to be the same.
    i cant think of anything else at the moment but if i do ill let you know
  15. herbs
    herbs Nobody but us chickens
    7 May 2001
    Its called a crossover cable or X-over cable , never heard it called a rollover cable but then I ain't heard of a lot of things.
  16. felix the cat
    11 Jan 2002
    rollover cable is a new one for me aswell....
  17. Draxin
    29 Nov 2001
    well i was tought it was a rollover but hey tamato tomoto right
    but im enrolled in the Cisco networking academy so i hope they know what they talking about
  18. monolith
    monolith True Friend
    5 Mar 2002
    Cisco has something called a rollover cable, that's why. I believe crossover cable is related to rj45->rj45 network cable, whereas rollover cable is used to connect the BMM console port to a console terminal or modem.
    http://www.cisco.com/univercd/cc/td/doc/product/fhubs/bmmicg/bmmconn.htm
    Cheers.
  19. ocha
    ocha Minimodder
    29 Dec 2001
    a roolover cable is something that a cisco router uses in its first stages to be configed. It is a small telephone like cable that attaches(using and adapter) from the COM port to the RJ-11 port on the back of cisco products they usually called console ports
  20. Draxin
    29 Nov 2001
    ok first off as rollover cable is used for router setup second it isnt an rj-11 conection thats what the phones use the router uses an RJ-45 conection origanly when i mentioned a rollever i was thinkg cross over
    1-------1
    2-------2
    3-------6
    6-------3
    that is how the lines are wierd
