Networks help needed
Discussion in 'Hardware' started by ocha, 29 May 2002.
  1. ocha
    ocha Minimodder
    29 Dec 2001
    ok well with all of that done, (I.e the networking stuff) i still cant get into the two computers for the opposite one. I am using a switch because i will be putting a router/modem on the LAN as well to give everyone access to the net through it. Could it be the NIC's I have a onboard NIC on the ME machine and a £7 Dabs value NIC that i got from a friend, or could it be a ****ty cable. Also do i need too turn XP's guest account on?
    Thanks for all your help hopefully it will work soon
    Lm
  2. MadGamer
    MadGamer What's a Dremel?
    18 Feb 2002
    Just try to find a cross over cable so u can see if the nic on both machines work than u can say that there is nothing wrong with the nic and test the cables and switch to see if they work.
  3. ocha
    ocha Minimodder
    29 Dec 2001
    at last
    ok i upgraded the ME machine to XP after a lot of tweaking with the CD and all works fine now yay! now i must share the ADSL over the LAN and get each comp to access it via the LAN but thats at a later date
