Rant help on finding a salt water pump, a tad random I know...
Discussion in 'General' started by kingred, 10 Apr 2014.
  1. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    I'm having a bit of an issue, I am struggling like all hell to find a salt water pump it needs to be quite a high flow (Above 12m3 per hour) for a friend, can anyone help as its starting to do my absolute head in looking.
    I just want a basic one with no stupid swirl pot thingo (or filter) can anyone help out?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Is it for a boat or a marine tank?
  3. kingred
    27 Mar 2008
    Its for transferring salt water quickly from one tank to another, low pressure, high flow rate.
    I also noticed I shouldn't make threads late at night :(
  4. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    Why not use a hose to siphon the water?
  5. kingred
    27 Mar 2008
    because it needs a pump as I need to shift 210 Litres per minute.
  6. Unicorn
    25 Jul 2006
    You can change the thread title in the advanced editing view :)
  7. DXR_13KE
    14 Sep 2005
    I remember doing hydro power tests with a 1000L tank and the thing would not last long enough for adequate results, the tank was about 8 floors up and the hose was about 10 cm in internal diameter.
    How about a venturi effect pump?
  8. kingred
    27 Mar 2008
    Ideally centrifugal as the tanks are on the same level, and the pump is mounted on the floor (same level as the base of the tank). Plus cheapy centrifugal pumps are cheap.
  9. Krikkit
    21 Jan 2003
  10. Nexxo
    23 Oct 2001
    --shakalaka!
