Modding help on macromans case
Discussion in 'Modding' started by sboy, 12 May 2002.
  1. sboy
    sboy What's a Dremel?
    6 May 2002
    i want this its so cool congrats macroman great job:):):)
    now is there a guide on how to make the baybus thingy and where to find the parts for it (note i live in uk)
    any help would be great thanks sboy
  2. Wyzzord
    Wyzzord What's a Dremel?
    15 Nov 2001
    The baybus seems to be nothing more than a regular one that has been inset so the nobs are protruding less!!
    From the article: "The fanbus is a 4 channel electronic affair with press-on/press-off rotary speed controls. These controls are mounted on a sub chassis, which is bolted to the drive bay front panel. The control knobs are sunk into the panel and have been drilled out to accommodate a red led. The front panel is backlit with blue neon string. All the front panel wires are connected to the circuit board via plugs and sockets to facilitate easy removal. The fanbus circuit board is mounted in a cut down case off an old busted CD drive."
    "3mm nuts and bolts retain the control mounting plate. The front facing surface of the mounting plate was covered in chrome tape to reflect back the light from the neon string. This helped to give a very uniform lighting effect. "
    As for the parts, I am sure that Maplin
    For a guide... check this out at VH
    or this one @
    Bit with Maplin stock codes
    These are not the EXACT guides on how to do this exactly...but with a lil' imagination..you can accomplish this!! If you have any ??? let me know!!
  3. macroman
    macroman The One
    3 Sep 2001
    This is pretty much the circuit used, the only difference being, the pots switch is in line with the feed to the fan to switch it on/off.
  4. Wyzzord
    15 Nov 2001
    Thanx Macro...I forgot to mention that!!!
  5. sboy
    6 May 2002
    How much in total did this cost to make matey
  6. nico
    nico What's a Dremel?
    9 Mar 2002
    could you please just quickly edit the image to show the change you made with the pot? I didnt quite get it.
  7. Wyzzord
    15 Nov 2001
    Nico...Which change are you talking about!!??
  8. sboy
    6 May 2002
    help Rheostat 50 ohm – FX97F maplins dont do them anymore anyone know where i can get them?
  9. sboy
    6 May 2002
    Macroman how much would you charge to make me one of them just for interest?
  10. nico
    9 Mar 2002
    read his post above. above the picture he said somehing about some thing he made different from the picture of the curcuit. And i didnt understand that part.
  11. macroman
    macroman The One
    3 Sep 2001
    The switch is part of the pot I used.
