I want to wire up 20 led's in parllel to light up something for my girlfriend. Im not very knowlegable when it comes to this so I thought id ask the experts. I found out that I need 16.5 Ohm resistor. (12V input, 2.1V leds at 30mA) Am I correct in thinking that I need 20 resistors wired up to the 20 leds or just one resistor going to all of the leds? Im pretty sure I need 20 resistors but I was just checking before I bought 19 more than needed! Thanks for the help!
i think logically you would just need one at the begining because the voltage wont suddenly go back up after first LED
I set it up in that fashon to try it out and after a few seconds the resistor became very hot and started to smoke.
My guess is that you're using a typical 1/4w resistor. This is a bad thing. What you just did was well on the way to making a miniture light bulb. The resistor needs to dissipate a total of (8.9v * .03A * 20) 5.34w. I'm surprised you didn't instantly blow it up, as you're putting about 6 times as much current (maximum current a resistor can handle is expressed as (P/R)^.5) as it can handle. I'd consider making a series-parallel arrangement of LEDs. A 5x4 net of LEDs (5 LEDs in series, 4 parallel strings of 5) with a resistor for each string would be the best setup. In that case, a ((12 - 10.5)/.03) 50ohm resistor would be needed for each. And you can use 1/4w resistors as well, a 50 ohm resistor can handle .07A of current. Plus, if one LED fails, then all the LEDs in that string will simply stop lighting rather than blow up.
Stevey: Just a little bit of Algebra, that's all. First, two equations must be established, V=IR (Voltage = Current * Resistance) and P=IV (Wattage = Curent * Voltage). Substitute V for IR, and we get P=I^2R. To solve for I, divide P by R (P/R = I^2) then find the square root of both sides ((P/R)^.5=I). .25/50 = .005. .005^.5 = .0707106781A or 70mA. Prnk: if you were to do it like I explained in my last post, it'd look like so: Code: 12v - - - - - - - | | | | < < < < > > > > < < < < | | | | v v v v - - - - | | | | | | | | v v v v - - - - | | | | | | | | v v v v - - - - | | | | | | | | v v v v - - - - | | | | | | | | v v v v - - - - | | | | GND - - - - - - -
