Cooling Help picking CPU and VGA waterblocks
Discussion in 'Hardware' started by Geektechnica, 1 Jun 2004.
  1. Geektechnica
    Geektechnica Minimodder
    11 May 2004
    I'm pricing out a watercooling set up for my P4 3.0E, here is what I have so far:
    Ice Xtreme 120MM Radiator $68.99
    Hydor L30 320GPH Inline/Submersible pump $46.99
    Bay-Res Revision 2 Reservior $24.99
    I'm going with 1/2" silicon tubing all around. What I need now is to find out what are the best waterblocks (with 1/2" fittings) for my P4 3.0E and my ATI Radeon 9700 Pro.
    Please, all comments and suggestions are welcome, both about the waterblocks and the other items I have selected. This will be my first time watercooling, so I have no experience with these parts and if they are any good.
    Thanks a lot.
  2. Geektechnica
    11 May 2004
    Anyone?
  3. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    YES. dont get a black ice radiator. get a good heatercore off of www.dangerden.com or www.dtekcustoms.com. much better and CHEAPER
    as far as waterblocks id consider the danger den tdx that just came out. i want one so bad. heck all of danger dens blocks are Great. i bought all swiftech gear last christmas and im ready to switch to danger den.
  4. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    Ok, I personally wouldn't go with silicone tubing. It is slightly water permeable, so you have to top it up every now and again. When I say slightly, I mean very slightly, no danger to components.
    The TDX is a good block.
    Then I would probably get a danger den maze 4 gpu block.
    Get a good rad, either a heater core, or a BIX II (expensive, but good if you want the system to look nice.
    Get any of the tubing from danger den, though I'm not sure about the UV stuff.
    And the, I'd get a DD Laing D4 12V pump, again from danger den.
    That way, you're getting all of your stuff from one shop.
    8-ball
  5. Geektechnica
    11 May 2004
    Awesome. Thanks for the replies.
    Off the top of your head, do you know if DangerDen accepts paypal?
    Ah, I'll find out soon enough. Heading there now.
