Windows Help please - major hardware upgrade - what do I tell Windows?
Discussion in 'Software' started by Cleggmeister, 12 Oct 2009.
  1. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Howdy!
    I'm about to perform a fairly major hardware upgrade on my PC and would like your recommendations for configuring Windows so that all is well after the change.
    Currently I'm running a A8nSLI mobo, Athlon 4200+ (socket 939), 2Gb DDR-400, 8800GT and Windows XP Home installed on a SATA drive. I have another SATA drive connected with games, Steam, documents, music, etc...
    I'll be changing to a P6TSE, i7-920, 3Gb DDR3 RAM, etc...
    Can I just go ahead and upgrade, connect the existing hard discs, and boot up as normal? I was going to disable the AMD dual core optimiser/driver but will I need to do anything else?
    Many thanks in advance.
    Cleggy.
  2. Radical_Monkey
    Radical_Monkey Dremel > Lightsabre
    27 Feb 2008
    Hey welcome to the forum!
    From my experience, you'll need to change the drivers for your new mobo and any other new hardware that would require drivers, i.e gfx card, sound card etc. Also if you change more than 3 pieces of major hardware you'll need to reactivate windows within 3 days. So make sure you have your licence key handy.
    I would recommend un-installing all the drivers for the hardware you're going to change and then installing the new ones after everything's working.
    R_M
  3. Krikkit
    21 Jan 2003
    Pretty much as Radical suggests - uninstall as many drivers as possible (and have a restart inbetween so that it boots with no drivers installed, just to be sure there's nothing left), then hope.
    It won't always work, so do backups of everything and make sure you've got all the relevant program files etc first. :thumb:
  4. EnglishLion
    EnglishLion working for the good of mankind...
    2 May 2008
    Agreed. Take off all drivers first, then rebuild and finally reinstall the drivers. Don't forget that the XP CD also has a windows repair option that can be useful if all else fails.
    Personally with a major rebuild like this I do a fresh install anyway but that's just my preference!
  5. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Is a clean install out of the question? Because that would be the best method.
  6. Cleggmeister
    12 Oct 2009
    Thanks folks, I've decided that a completely fresh installation will be best, new HDD ordered and installation discs ready!
