Modding help please - Orange fan grills?
Discussion in 'Modding' started by Buzzons, 12 Feb 2016.
  1. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    All,
    Is there an easy way to turn a standard silver or black 140mm fan grill into a bright orange one? (to match the colour of a bequiet 800 case)
    I can't seem to find any orange fan grills :(
  2. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Good quality enamel spray paint would do the trick, but you will likely have a problem with paint chipping if you don't prep the surface. I imagine black grills will be easier to paint than the chromed ones.
  3. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    awesome - will try and find some matching paint
    thanks
  4. Kevin_CL
    Kevin_CL What's a Dremel?
    27 Jan 2015
    This thread is a little old, but you may also look into getting them powder coated. The finish will last forever, and for some small parts like that it shouldn't cost much. Something like a bright "safety orange" is a pretty standard color for shops to stock too.
