Motherboards Help please with an Asus P6T deluxe
Discussion in 'Hardware' started by onthejazz, 11 Mar 2010.
  1. onthejazz
    onthejazz What's a Dremel?
    17 Feb 2010
    I had all my components ready for a new build and was so excited!! However, with my amazing forsight I bought a B listed Asus P6T deluxe from aria, which only came with the board and no accessories.
    I have just read the downloaded manual and to connect the front panel I should of had an Asus Q-connector'. Can anyone tell me how to connect my front panel without this connector?
  2. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I have the P6TD deluxe and I don't need it. Don't know if it helps
  3. onthejazz
    17 Feb 2010
    I'm not good enough at PC building to connect the pins without an annotated diagram, do you know where I could find one?
  4. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I just downloaded the user manual here
    on page 2-37, there's a diagram of the pinout:
    Guest-16 likes this.
  5. onthejazz
    17 Feb 2010
    I can't believe I missed this, thanks for saving my day!!!! :D:D:D
  6. Kovoet
    26 Aug 2009
    make sure they face up as well
