Help Please!
Discussion in 'Hardware' started by Strategy, 17 Jan 2006.
  1. Strategy
    Strategy Banned
    19 Jul 2005
    Does anyone have or know where I can buy (or know someone that could make) a 20pin to 20pin adapter? Needs to be between 5-15cm long. But doesn't matter if it's longer.
  2. fantastic dan
    fantastic dan Minimodder
    26 Jan 2004
  3. Strategy
    Strategy Banned
    19 Jul 2005
    It is, but I need it to be 20 pin to 20 pin, and both male ends. That site only has 24 pin to 24 pin.
  4. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
  5. Strategy
    Strategy Banned
    19 Jul 2005
    itx board to snap in psu. they are both 20pin.
  6. Hellboy787
    Hellboy787 What's a Dremel?
    3 Nov 2005
    if you cant find one why don't you just go down to Maplin and buy the 20 male to female ext. and then buy a 20 pin male, which they also sell and modd it to your needs.
  7. Strategy
    Strategy Banned
    19 Jul 2005
    It's what I'm going to have to do. Just thought their might actually be somewhere that sells a male to male 20 pin to 20 pin adapter.
  8. phuzz
    phuzz This is a title
    28 May 2004
    It could be worth looking at companies that specialise in ITX, but it should be pretty easy to knock one up, and then you can make it longer or shorter or whatever...
  9. Strategy
    Strategy Banned
    19 Jul 2005
    I've orded two 20 to 24 pin adapters. I'll splice them together when they arrive. Just annoyed it cost me a tenner!
