Modding Help required, building a case
Discussion in 'Modding' started by darkvirus999, 21 Jul 2007.
  1. darkvirus999
    darkvirus999 beware of hackers
    21 Jul 2007
  2. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    Welcome to the forums. I'd start with a frame made out of aluminum. A lot of guys make theirs out of angle aluminum and rivits which seems to work ok. Others like to glue it which works too. Then you can just get sheets of aluminum and make your side panels. Not so sure of the front design though, what are all of those things (that look like stealthed drives) for?
  3. darkvirus999
    21 Jul 2007
    yes they are stealthed, large 2 on right are cd drive bays below it is intendended to be a bay for a floppy drive or card reader. the top left is for a display i have and the one below it is for a fan controller
  4. greensabbath
    19 Apr 2005
    Alright then, so what is it exactly that you need help with?
  5. capnPedro
    11 Apr 2007
    First things first, get some (detailed) scale drawings on the scene. I don't know what all the cool kids are using these days, but I have experience with AutoCAD.
  6. Zurechial
    Zurechial Elitist
    21 Mar 2007
    CapnPedro clearly isn't cool enough to be one of the cool kids :p
    Where the cool kids go!
  7. darkvirus999
    21 Jul 2007
    well i can use autocad well but not got it innstalled atm, i could do with sum ideas on how to build the frame.
    im thinking of making a cube fram which i can then bolt the faces to. i will be usin 1-3mm thick aluminium for the faces an not sure what to use for the frame. some ppl have said to use lengths of angle but that might get aquard getting all the ends to alight neetly
  8. greensabbath
    19 Apr 2005
    Look at some of the cases on bit-tech. A lot of them use the angle aluminum frames and they have various ways of building them of various difficulties.
  9. darkvirus999
    21 Jul 2007
  10. darkvirus999
    21 Jul 2007
  11. Teyber
    Teyber ******
    18 Mar 2007
    you should plan out the inside. thats really important.
    Not quite understanding what you need help with?
    just to make me drool, can you post some pics of your workshops(S?)
  12. darkvirus999
    21 Jul 2007
    would like 2 but its not at my house, its the workshop in my dads business so i'll be spending all my time there soon on the case
