Modding help scratched window
Discussion in 'Modding' started by MiNiMaL_FuSS, 30 May 2004.
  1. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    the cat decided it didnt like my nu cathode and decided to try to get rid of it by itself. my window has quite afew (but light) scratches.
    is there anything i can do about this?
  2. SJH
    SJH Minimodder
    24 Dec 2003
    If they're only light you could use toothpaste and a cloth. Rub it in over the scratches and the grit in the toothpaste (actually limestone did you know?) will descratch it :p
    For deeper cuts this might not work though.
    -Sam
  3. wharrad
    wharrad Minimodder
    26 Jul 2003
    I read a thread on here a couple of days ago about a tube of stuff you can rub onto things and it'll help get rid of the scratches - although, you're only going to have luck with minor things...
    I know this post isn't much use, as I haven't told you what this tube was - but try searching "scratched mobile" or "scratched iPod" - should bring it up...
  4. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Some high grit sand paper with a buffer should do the trick if the scratches are deep.
  5. MiNiMaL_FuSS
    24 Dec 2003
    the toothpaste worked!!!
    god bless u sir!
  6. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    It was this thread
    I don't know if shastings read it but i swear by the toothpaste thing
    Hope he didn't steal my idea :hip:
  7. wharrad
    wharrad Minimodder
    26 Jul 2003
    Cheers!
  8. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    Makes me wonder what toothpaste does to your tooth :naughty:
  9. 0013
    0013 What's a Dremel?
    7 Mar 2004
    or sandpaper...
  10. Bones
    Bones What's a Dremel?
    14 Nov 2003
    lol im sorry to bring back an old thread but i was wondering if this technique with the toothpaste would work on an ipod. If not are there any other ways to help remove any scratches on an ipod? Thanks!
  11. 0013
    7 Mar 2004
    it works on coolermaster heatsinks to give it a smoother surface, I hate the standard CM finish ... quite rough ...
  12. Bones
    14 Nov 2003
    I got home from school today and decided to give it a try and it sure did work! I had a pretty good amount of scratches on it and i used the toothpaste and it cleared it up. I still have some scratches but nothing major. Thanks for the tip!
  13. kergareth
    kergareth What's a Dremel?
    6 Jul 2004
    Would this work on cd's?
  14. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    There's a stuff that's made especially for acrylic, boat windows, nascar car winshields etc plastics, it's called NOVUS comes in three parts for light to bigger scratches.
    I forgot where i put the link but if you google NOVUS you'll find tons of places selling the stuff :thumb:
