Electronics Help to find mini touch-screen monitor
Discussion in 'Modding' started by AnG3L, 10 Apr 2011.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Hey guys I need your help! I need to find a small touch-screen monitor for my next mod.
    I think 7 inches will be nice, also 10 inches will be my limit. Please if you know any good companies send me some links and info! Thanks in advance! :thumb:
  2. cchr
    cchr Minimodder
    24 Nov 2010
    check out the lilliput touchscreens bro, they are very popular and they are widely available:thumb:
    link
  3. shomann
    shomann Minimodder
    5 Sep 2003
    Where do you plan on sticking it?
    The Mimo monitors are driven from a single USB cable, making for some very flexible design options. If you are looking for a simple control surface or graphics, they are fine. If you want something with a higher quality or daylight readable, then these aren't it.
    http://www.mimomonitors.com/
  4. dunx
    dunx ITX is where it's at !
    1 Sep 2010
  5. AnG3L
    19 Mar 2009
    Thanks guys for all the replies much appreciated!
    Well, the monitor will be modded with a pair of two custom made speakers and it will be
    attached on the case in a way that it will easily removed so the pc can be used with bigger monitor setup.
    I am also thinking on some regular monitor (non touch).
    If you have more info that would be awesome! Thanks again! :)
  6. AnG3L
    19 Mar 2009
    Also I would prefer if the company is in Europe for tax free problems ya know! :)
  7. jrs77
    jrs77 Modder
    17 Feb 2006
  8. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Might be a bit small for your requirements but i've been bringing some over from China for a year or so now.
    They are 6x5.6"(4:3) 640x480 and are touch screen with USB interface and had some bezels made up so they can fit into three 5.25 drive bays.
    I also have some widescreen 4.3"(16:9) 480x272 on their way which will fit into two 5.25 drive bays and although the picture quality is good, they aren't really practical for running Windows due to the actual size but the larger ones are fine.
  9. silent1313
    silent1313 What's a Dremel?
    22 Mar 2011
    Coolmiester, could you please share your source of the screen and approx. the cost. That screen looks amazing. I am very interested in the one in your you tube video. That screen would be the perfect solution to my headless home server, cause I would only need to use it during recovery and installations etc.
    THANKS in advance!
  10. AnG3L
    19 Mar 2009
    Yeah I am interested on that too buddy please PM some more info and where I can get it etc etc. Thanks!!!!
  11. Dragonite
    Dragonite Minimodder
    15 Feb 2011
    Yeah same here I might be very interested in that one. Atm I was planing to use a Lilliput screen for my project but it can't hurt to have more then one option to choose from.
  12. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    I'd also be interested in one
  13. stuartwood89
    20 Aug 2008
    Ooh me too! Looking for something that will fit inside two 5.25 bays for a mod that I'm planning.
  14. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    i'm looking for a usb touchscreen as well, though one that is ultrawide format like 2.39:1. it looked like it would have had a 10"-12" diagonal. so pretty close to the size of a keyboard. i was thinking it would be great as a control surface / virtual mixer. i saw one once in a pic somewhere on here, but haven't been able to find it again to see who makes it. anyone know?
  15. stuartwood89
    20 Aug 2008
    I'm looking that would fit within a 14cm x 9cm space. Would you happen to have something like that?
  16. coolmiester
    31 Dec 2002
    I have twelve of the larger ones and six of the smaller widescreen ones in transit from China which should be here within the week but i’d rather see how much i get hit at UK Customs before confirming a price.
    The first few orders slipped straight through customs but the last two i got stung for quite a bit which added about 10 quid to each screen which is why i decided to reduce the quantity this time around so time will tell.
    I’m also having some bezels made up in brushed alu so will post once i have those sorted so PM me if you’re interested.
  17. stuartwood89
    20 Aug 2008
    That sounds cool, do you have the dimensions (WxH) in centimetres for both LCD displays? I'll need to know if one would fit inside my HTPC case. I wouldn't need a bezel, as I'd be mounting it straight to the front fascia. Any information on the size of the controller board would also be great.
  18. coolmiester
    31 Dec 2002
    The larger 6x5.6"(4:3) 640x480 screen is:
    115mm x 87mm visible screen size
    126mm x 100mm overall size
    The smaller 4.3"(16:9) 480x272 screen
    95mm x 54mm visible screen size
    105mm x 65mm control board size
    Both come with 12v molex, USB interface for touch panel and VGA adaptor so are pretty much plug and play.
  19. stuartwood89
    20 Aug 2008
    Ahh thanks for checking :thumb:
    Does the controller board you use have to be connected to the LCD panel that it comes with? I only ask because I want something to fill the space a little more, and I could possibly source my own panel.
    EDIT:: Made a paper template for the visible screen size, and it actually looks to be perfect. The overall size though, I assume is the screen and the controller together, or the frame around the panel?
