help trying to find mobo
Discussion in 'Hardware' started by hobbs, 19 Feb 2006.
  1. hitman012
    hitman012 Minimodder
    6 May 2005
    If you have found these two boards that meet your specification, then I would choose Asus without a doubt. Are you sure that they're compatible with all your components?
  2. hobbs
    hobbs What's a Dremel?
    24 Jun 2005
    yes eccept the cpu, im worried about the 800mhz fsb on a 1000fsb cpu
  3. hitman012
    6 May 2005
    Sorry? That doesn't make sense... all Socket 939 motherboards and processors have a 1000MHz HyperTransport link, and all Socket 754 processors and motherboards have an 800MHz HyperTransport link. Where are you getting this information from?
  4. hobbs
    24 Jun 2005
  5. hitman012
    6 May 2005
    That's either a mistake or yet another limitation of VIA's chipsets :rolleyes:. Either way, you should be fine - having the HTT at 800MHz won't really affect performance. Asus' CPU support database lists the processor as being compatible.
  6. atanum141
    22 Jul 2004
    hes right the via chipset does only support 800mhz HTT which is weird as it looks like they can only pass the HTT very slowly. it seems more like a feature than a limitation on this chipset, its abit sad tho that you have to buy a sub-performing board.
  7. hobbs
    24 Jun 2005
    hmm now i have another problem amd 3700+ or a operon 146
  8. hitman012
    6 May 2005
    3700+. The Opteron is slower at stock than the Athlon, and since that motherboard is utterly rubbish for overclocking, the Optie is all but wasted (and the newer steppings overclock like crap anyway).
  9. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Yup agreed.
  10. hobbs
    24 Jun 2005
    ok thanks a ton guys. when id am2 due out? worth waiting?
  11. Shadowed_fury
    21 Nov 2003
    Due June. Not worth the wait IMO, it'll take a while to catch up and be worth moving away to.
  12. hobbs
    24 Jun 2005
    will am2 accept skt 939 cpus? or will it be all redone?
  13. Shadowed_fury
    21 Nov 2003
    Different Socket, Different Ram.
  14. hobbs
    24 Jun 2005
    geez there getting rid of all the old stuff
  15. atanum141
    22 Jul 2004
    no they arnt gettin rid of the old stuff, Am2 is just the next newer version of the 939 stuff. Its exactly the same as the 939 but it has 940 pins and uses DDR2 thats all.
    If you allready have 939 then theres no point in upgrading but people like me who are on SktA would prob upgrade to AM2 insted of 939.
  16. hobbs
    24 Jun 2005
    ha...im still in socket a land for about 3 years now and i really need a upgrade thats why im looking at skt939 can wait untill june
