Build Advice Help Upgrading my HP Elite m9060n
Discussion in 'Hardware' started by theangrygooch, 25 Feb 2010.
  1. theangrygooch
    theangrygooch What's a Dremel?
    25 Feb 2010
    Hey Guys,
    Just a curious question...been in japan for awhile, and now that im back i wanna upgrade my current computer for the best gaming. im in the process of upgrading my computer an HP Elite m9060n and i was seeking some advise on what i could pump into this machine and not blow it up. I'll provide some links to the my specs. Im running a Intel Core 2 Quad with 3gbs of ram. I wanna get as much out of this computer as i can. Seeking whats the best ram, graphics card, processer (if i can change it) and whatever else you guys think would be a nice touch. If you need any further information, please ask. Preping for Starcraft 2 and Diablo 3 (if it ever comes out :rock:)
    Swinging for a tree
    Gooch
    Comp Specs
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01197633&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3552382&lang=en
    Motherboard Specs
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077641&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=3552382&lang=en
  2. rollo
    rollo Modder
    16 May 2008
    5770 4890 5850 5830 should all work without alot of issues you will need to check the space though
    cheaper options would be a 9800 or a 4850
    id guess the power supply is a generic thing so id keep it to the latter 2. If you do want a card on the top then id upgrade to psu to a 500 watt branded psu
  3. theangrygooch
    25 Feb 2010
    lol with all these numbers i have no idea what your talking about lol. The ram? Graphics Card? im kinda confused lol:D
  4. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
  5. theangrygooch
    25 Feb 2010
  6. Dreaming
    31 Jan 2007
    What size is your monitor and what resolution? The really good graphic cards are only really needed for people with massive monitors on very high resolutions, 4850 will run anything else pretty much topped out I think.
  7. theangrygooch
    25 Feb 2010
    around 23" 1920x1080...i like how you recommended the links...any advice on a good psu for my comp? its a 630 w psu i believe
