Build Advice help upgrading
Discussion in 'Hardware' started by Dreamcometru, 19 Oct 2015.
  1. Dreamcometru
    Dreamcometru Minimodder
    11 May 2009
    Hi,
    id like to upgrade my rig.
    current specs
    corsair modular 650W psu
    msi p67a gd53 mobo
    gainward phantom 970
    some cheap corsair ram (4gb - 2 sticks)
    i5 2500k cpu
    1tb hdd
    would like to upgrade the mobo, ram and cpu.
    help and advice much appreciated
    ty in advance
  2. mrbungle
    20 Sep 2004
    Purpose?
    There are not many games a half arse clocked 2500K won't be fine with.
  3. Vault-Tec
    30 Aug 2015
    I really wouldn't bother.
  4. Goatee
    Goatee Multimodder
    19 Apr 2015
    Agreed, don't bother with the MOBO, RAM or CPU.
    I would suggest you get an SSD and install OS and key games on it. You will definitely notice the difference.
  5. Digerati
    Digerati Minimodder
    19 Feb 2011
    I agree with the suggestion to go with an SSD, but if that RAM is 4Gb total (2 x 2Gb), I would consider bumping it up to 8Gb - assuming you have a 64-bit OS installed.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Im still running a stock clocked 2500k with a 970 and I don't see any issues gaming.
    Skylake is tempting me but even then I'm going to wait for what ever is up next.
    See is definitely the way to go first.
  7. Dreamcometru
    11 May 2009
    ok thanks for yor replies. will look into an ssd.
  8. Goatee
    Goatee Multimodder
    19 Apr 2015
    I really like the Samsung software (both magician and clone) so I would recommend and 850 EVO.
  9. Dreamcometru
    11 May 2009
    hi again, just wondering if u should or even can delete stuff off your ssd with no worries? does that affect it somehow?
    do u need to defrag them at all? will that damage them?
    are there steps i need to take to ensure longevity of my ssd and if so what are they?
    im hoping to get one on black friday. are there any recommendations?
    thanks again
  10. Vault-Tec
    30 Aug 2015
    Defragging an SSD will likely screw it, yes. In any modern OS the option should not even be there.
    The best bit of advice I can give is to keep it clean and don't keep installing things onto it and then deleting them. TRIM will take care of garbage collection and will happen natively in Windows 7 and on. Just make sure you only have your OS and apps that go with it (things like CPUID etc).
  11. Digerati
    Digerati Minimodder
    19 Feb 2011
    You treat it just like a hard drive. So yes, you can delete files off it with no worries. You do not need to defrag SSDs. And Windows is smart enough to properly manage the SSD for you.
    Do not worry about longevity. Today's SSDs do not have the problems first generation SSDs did. This is one reason (besides less heat and less power) even big data centers are moving to SSDs over hard drives.
    I recommend at least 250GB. I like the 850 Pro if your budget allows - it has a great 10 year warranty! Otherwise, the Evo is great too.
