Electronics [HELP] USB to Somthing (Parallel / Serial / ???)
Discussion in 'Modding' started by Delta101, 22 Mar 2010.
  1. Delta101
    Delta101 What's a Dremel?
    22 Mar 2010
    Hi Guys,
    this is probably asked alot but i cant seem to find the answer i need anywhere.
    i have a PC with a parallel port and have been able to get leds flashing and stuff using C# and ipout32.dll, my problem is that the PC in my car has no Parallel port, serial port or PCI slots (ITX Mobo, running Windows XP)
    i have tried a USB - Parallel but them cables both just install as USB Printer and not LPT1
    so how would i go about controlling the LEDs in my car and avoiding the speaker thumps at startup?
  2. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    What mobo is it? Is it possible that it has a parallel port as a pinheader?
    Moriquendi
  3. lenne0815
    lenne0815 What has been seen cannot be unseen
    4 Jul 2009
    i think there are serial / pci slot cards, but i dunno if u could fit them...
  4. Boxcarr
    Boxcarr Will use any tool available.
    3 Dec 2009
    from what I have read you cannot directly (through code) control lights etc. with just a USB.
    There needs to be a decoder, I ran across a site that would allow you to control relays, lights, motors, pretty much anything you had the time/$/or creativity to try through the USB ports.
    try searching "control the world from my PC" & USB it should come up.
  5. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    USB-> Serial and USB-> Parallel converters won't work for what your trying to do as they don't work as true ports.
    Your best bet is as PCI Serial/Parallel card
  6. Delta101
    22 Mar 2010
    The Mobo is a :ZOTAC GeForce 9300-ITX WiFi
    thanks for the info about USB > Serial (Was gonna buy one and try now i dont have to)
    i have been looking at Arduino boards and am wondering if they will do what i need.
  7. dark_avenger
    9 Jul 2008
    Something like this might do the trick for you
  8. Boxcarr
    3 Dec 2009
    it looks like an Arduino would work. though I haven't heard of them until today.
