Help: Visual Studio 2008
Discussion in 'Software' started by Horizon, 16 Sep 2008.
  1. Horizon
    Horizon Dremel Worthy
    30 May 2008
    It's on my comp and I never really bothered to learn how to use it. I need it to write some C code but it doesn't seem to support it. In my programming class we use VS 6.0
  2. azrael-
    azrael- I'm special...
    18 May 2008
    I'm not quite sure if I understand your problem. You should be able to program in C using Visual C++ 2008 (which is part of Visual Studio 2008).
    Could you describe your problem in more detail?
  3. Horizon
    30 May 2008
    The build/link/compile buttons are missing. The help files say to type " cl simple.exe " minus quotes in command prompt (command window?) to compile code but when i do that it says " cl " command isn't valid.
  4. Krikkit
    21 Jan 2003
    Why don't you just try a free C compiler/ide? There're plenty about that are available under the GCC...
  5. Horizon
    30 May 2008
    I've tried a few and they seem broken in Vista.
  6. Horizon
    30 May 2008
    using Dev++
    nvm, it's in c++ mode...seems to work
  7. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    +1 to Dev-C++. And my beta copy has an option to use either C or C++.
