Help .Which CPU?
Discussion in 'Hardware' started by NiTr0, 26 Aug 2003.
  1. NiTr0
    NiTr0 What's a Dremel?
    16 Aug 2002
    Been looking again at getting another cpu for my system.
    I had a 2500+ Barton last week along with a Asus A7V8X-X mobo.
    When put together the system kept on locking up at ramdom intervals
    Tried diff ram (Crucial 2700), drivers, pci cards even a clean install. which was locking.
    Dumped my old 1.4 T Bird into the system and the problem went.. (Any Thoughts on this prob?)
    RMA'd the chip back and now i have the choice of another Barton (Retail) or a ATHLON XP2600+ Thoroughbred OEM
    Will the barton be faster than the Thoroughbred as the T Bred has a higher core speed.
    Spec atm is:
    Asus A7V8X-X
    768mb Crucial PC2700
    Sonicfury
    Creative GF4 Ti4400
    Enermax PSU 430w
    TIA..
  2. Mister_Tad
    27 Dec 2002
    i personally would go for the barton, as they are pretty good overclockers.
    will you be overclocking?
  3. NiTr0
    16 Aug 2002
    I doubt i will be overclocking the cpu, having the trouble with the last barton to run at all was a headache :worried:
  4. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    The couple of MHz in clock difference doesn't outweigh the large improvement you get with the extra L2 cache. And the Barton is a good overclocker if you ever feel like doing that - go with it.
