Motors Help wiring a car stereo please
Discussion in 'General' started by Cleggmeister, 17 Jan 2014.
  1. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Hmmmm....
    1990 car
    2013 stereo
    No problem though I since I have an ISO to bare wire cable, and it looks simple.
    So, I've connected the earth, battery+ and ignition+ but there's no life from the stereo, regardless of whether the ignition is on or not.
    I measure good voltage as I'd expect so there's definitely power.
    Nothing else is connected - no aerial, speakers or dimmer, and the unit is not mounted yet, it's just loose on the car seat.
    Help!!!!!
    PS: The old Blaupunkt Radio Cassette works fine...
    Cleggy and his vintage car/new stereo.
  2. Cleggmeister
    12 Oct 2009
  3. Cleggmeister
    12 Oct 2009
    I have a power aerial, which goes up when I turn the radio on, down when I turn the radio (or ignition) off, if that helps.
  4. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Are you sure the head unit actually works?
    What happens if you connect the speakers as well?
  5. Cleggmeister
    12 Oct 2009
    Sorted, thanks Mercedes for using brown as earth!
  6. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    Brown is often earth in DC power, especially old systems.
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    That's as bad as TVR using all black cables, :D
    Or the moron who rewired another of ours, who used red for an earth! :D
  8. Cleggmeister
    12 Oct 2009
    Head unit
    Mic
    Happy me, all sorted, and it's very nice to have everything integrated without Parrots, CD's, tapes and wires. Just need to put some black duct tape around the inside of the cage to hold it a bit firmer and mask off the bare metal.
    It sounds fine, though doesn't like FLAC which is a shame since my 2500 albums are all encoded that way. Looks like DBPoweramp will come in handy for a batch conversion next weekend. Wu-Tang first, of course :)
    New speakers and cables next, assuming I can pull them through taped to the existing ones - don't fancy pulling the carpet and seats out...
  9. Krikkit
    21 Jan 2003
    Ooh, zebrano. Heated cloth as well, magnificent!
  10. Cleggmeister
    12 Oct 2009
    It's always the late 80's in my car, that's why I love it so! And it took me ages to find an interior that matched my boudoir so closely :)
  11. Cleggmeister
    12 Oct 2009
    A wee bit more help please... I paired this no worries with my 12 year old Nokia for phone calls, and after a bit of a faff paired it with my work phone (Samsung Galaxy S).
    My wife paired her new iPhone no worries but I can't get my Nexus 7 to pair for love nor money. The two things see each other and the stereo shows "Connecting" but always fails. No biggie as I'll not use it, but it's bugging me all the same...
