Electronics Help wiring a illuminated automotive toggle switch?
Discussion in 'Modding' started by bajastx, 26 Nov 2008.
  1. bajastx
    bajastx What's a Dremel?
    22 Jan 2002
    Hello,
    How would I wire a standard illuminated automotive toggle switch if I want the light in the switch to be on when the switch has removed power from the item it's controlling.
    This switch will be controlling a 12v fan, but I want the light in the toggle switch to be on when the fan is off.
  2. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    if you have a diagram of it connected normally, you will see that there is one Gnd connection, on my switches the terminal is marked "G"
    and there is one called "B+" that is normally for the supply to the switch, but here you connect the load.
    and the last terminal is marked "load" (on my switch) connect the supply here.
    Now the light in the switch will be lit all the time, and the switch controlls the fan
  3. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    It depends on two things:
    1: Do you want constant light, or do you want the light to turn off when the unit is turned on?
    2: What switch you have, and how it's constructed. If we get more info on what switch we are talking about, it will be much easier to help :)
  4. bajastx
    22 Jan 2002
    1) I want the light to be on only when the fan is off.
    2) This is the switch I have. It has 3 terminals labeled 12V, ACCY, and GND. I believe the GND is only the ground for the light and the other two terminals are the interruptor legs.
  5. bajastx
    22 Jan 2002
    I know I can do this with a relay, but I'm trying to avoid that.
  6. Smilodon
    25 Mar 2003
    I see. What you need to do is to connect GND to the positive pole of your battery, and then connect both 12V and ACCY to the positive pole on the fan. The ground on the fan goes directly to the ground pole on the battery (Or to the chassis in the car).
    Mind you, this isn't the best way to do it, ans some current will flow trough your fan. If the fan is big enough there shouldn't be any problem, but if it's a small fan (Like a computer fan) it may start turning slowly even when the switch is off.
    What happens is that the bulb in the switch will draw current trough the fan to make it glow (The current the bulb allows trough shouldn't be enough to turn the fan). When the switch is turned on, it will short out the bulb, giving the fan full power.
    If the bulb in the switch is a LED, you may have to connect the switch the other way around (12V and ACCY to the positive pole on the battery, and GND to the positive pole on the fan)
    I suggest you test this out before you make a permanent solution. :)
  7. bajastx
    22 Jan 2002
    Thanks for the help. I'll give that a try.
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Close but no cigar.
    Code:
     (12V)--+-o/  o-+--(ACCY)-----+
            |      lamp          FAN
            |     (GND)           |
            +-----+12V           0V
    It will work if the fan is a much higher wattage than the bulb (and if the "bulb" isn't a LED). My doorbell light uses the same principle, with only two wires to the push needed.
  9. Smilodon
    25 Mar 2003
    Yes, it's cigar:
    edit: The ability to upload pictures on the new forums is simply awesome! :D :thumb:
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I think you'll find the switch internal is not quite as per your drawing... ;)
    Code:
                   Lamp
                  (GND)
  11. Smilodon
    25 Mar 2003
    DO'H! Of course! :duh:
    When I look at it, my switch would do nothing more than to just short out if used "correctly"...
    So bajastx: Do as cpemma says. He actually knows what he's talking about. hehe
  12. Alekoy
    Alekoy Ostekake!
    28 Dec 2003
    The switches I have uses a LED for the light, and leds do, (as most of us know) only work with the correct polarity.
    So this is how you need to connect it if there is a LED.
    As Smilodon mentioned, the fan will have a little current running thru it, but hopefully not enugh to make it run, or not stop...
    oh, and sorry for the paint drawing..
    FORK! now I saw that you had a link to the switch....
    not the same as I was thinking about, but it still probably has a LED..
