Modding Help with a blowhole
Discussion in 'Modding' started by atc95, 12 Jan 2013.
  1. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
    Hi,
    I am about to start my case-mod see thread, but I am concerned about how and what tools I need to make the blowholes.
    I need 2x 120mm blowholes for an h100i (can you get a stencil for this?)
    I need 2x92mm blowholes for the 2x 92mm intake fans.
    I will be cutting through thin metal and/or plastic (an xbox case) and I currently have a dremel.
    I have looked at holesaw attachments for a drill but the only ones I can find are 89mm, 102mm and 127mm, are there any 120mm attachments or other tools you would reccomend.
    Thanks,
    atc95
  2. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    atc95 likes this.
  3. atc95
    3 Dec 2012
    thanks, any idea where you can get one in the UK, I can find loads of 127mm but that's too big, also for the h100i do you just use 2x 120mm blowholes next to each other or is there spacing between them (thinking there is spacing as radiator is 275mm long).
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    240 rad temps
    mount the fans see what the spacing is between the 2 fans
    google and see if you got a BSS know they do them but try builders or plumbers merchants
  5. atc95
    3 Dec 2012
    what about this? Will it fit a black and decker h501 10mm drill (really old, but only one I have).
  6. bulldogjeff
    2 Mar 2010
    Wicks do them. They do a 116 ideal for 120 holes and one bang on 92mm
  7. atc95
    3 Dec 2012
    cool, while I am on the topic of templates, does anyone know an accurate mini itx template, I am trying to do all the power tool work now and then fitting in a week or two (along with the project log!).
    Also what do I need to attach the hole saw to my drill? It's a black and decker h501 10mm drill
  8. bulldogjeff
    2 Mar 2010
    You can by the hole saw attachment in wicks with the pilot bit. You only need one as it fits all the cutters.
  9. atc95
    3 Dec 2012
    Found this for 114mm: 114mm
    and one of these for the 92mm: this or this.
    So I just need something like this to attach everything to my drill?
    Sorry for all the noob questions but this is my first mod so don't want any screw ups :duh:
  10. bulldogjeff
    2 Mar 2010
    Yep thats spot on. All the right bits. And the good thing is that all the fitting are universal so are compatible with one another in most cases.
    atc95 likes this.
  11. atc95
    3 Dec 2012
    Another quick question, what drill bit (diameter) do I need for M3 screws and motherboard standoffs and can I use a dremel attachment as I have a workstation stand for my dremel so it will be a lot steadier than a drill?
  12. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    Make sure its m3 and not the 11/32 ( think its that I'm on phone and can't remember )
  13. atc95
    3 Dec 2012
    The dremel attachment I am looking at has diameter 3.2mm, I'm guessing that is M3 with a bit of clearance?
  14. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    To tap m3 u won't 2.3 or 2.5 for loose
  15. atc95
    3 Dec 2012
    I have a 2.4, that should be fine right?
  16. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    yep there loads of tap guides on web :D just remember slow and easy don't force trying to get done in a hurry with something that small they can snap easy
  17. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Was the 116mm holesaw in Wickes online or in-store?
  18. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    wickes 116mm you will need a Hole Saw Arbor as well if you not got one.
  19. atc95
    3 Dec 2012
    so what is easier to use as I already have this for my dremel or should I invest in a hole saw and arbor? All the web guides say you can use a dremel (but takes time) or a hole saw or a jig saw, I have no idea which is best.
  20. bulldogjeff
    2 Mar 2010
    I bought mine in store. B&Q probably have them in that size as well.
