Modding Help with a blowhole
Discussion in 'Modding' started by atc95, 12 Jan 2013.
  1. bulldogjeff
    2 Mar 2010
    The best way to do it would be a hole saw in a bench mounted pillar drill, 2nd best is a normal drill or a good cordless drill, which is what I use.
    It always helps to center punch the center of the hole so it guides the drill bit and stops it from jumping about. On plastic I use a 3 mm bit to pilot the hole first. Then go in with the cutter.
  2. Parge
    16 Jul 2010
