Electronics Help with a KDS Radius rad-5 LCD
Discussion in 'Modding' started by XDude, 18 Sep 2005.
  1. XDude
    XDude What's a Dremel?
    11 Nov 2003
    A friend give me a 15" KDS radius rad-5 LCD monitor, after conecting and powered I noticed that it's complete white when I connect it to my laptop or my desktop.....
    Even unconnected when I turned on the screen it's white....
    May I cosider that it's damaged?
    Thanks
  2. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    yes I would probably guess that the monitor is damaged. All the LCD's Ive seen will put up a test pattern or message when they arent getting a signal. Or at elast when they arent hooked up. My LCD can tell the difference between being hooked up and not getting a signal, and not being hooked up. So if you have the cable disconnected and it still does not do anything, chances are its broken.
  3. XDude
    11 Nov 2003
    :waah: :waah: :waah: :waah:
    :idea:
    For Sale:
    1 Catode tube + Inverter
    1 LCD Stand, with screws
    any interested?
  4. MattMc
    MattMc What's a Dremel?
    5 Oct 2003
    Can you bring up the on-screen menu? If so, maybe reset the settings to the defaults. Is there only one input? Maybe one input is bad and another (if it has one) works.
    Sounds bad to me also. Maybe that's why your friend gave it away :hehe:
  5. XDude
    11 Nov 2003
    There is no text, messages or menu, only a white screen when turn on or when it's attached to my desktop or my laptop
    well, he will give me an old HP laptop without power adaptor tomorrow.....
  6. star882
    star882 What's a Dremel?
    19 Mar 2003
    Have you checked the internal connections?
  7. ConKbot of Doom
    2 Jul 2003
    and the chances of that not working are? :p
  8. XDude
    11 Nov 2003
    The laptop works, the only thing it's that the power adapter it's damaged and his client give away the computer.....
    That's the information that I had.....
  9. XDude
    11 Nov 2003
    It's hard to disassemble the monitor....
    I check it.....
    The thing that takes my atention was some adhesive tape made of metal...
    (maybe and electromagnetic shield) and now It think that it's causing some short :duh: ....
    I'll check it again right now!
  10. XDude
    11 Nov 2003
    :sigh:
    Bad news.... :waah: :waah: :waah: :waah:
    After checking the contacts I see that the clip that holds the flex on the controller board it's broken....
    I try to hold the flex in several ways, and the screen still white when attached to my laptop..... the board it's damaged.....
