Cooling Help With A Laing DCC Pump
Discussion in 'Hardware' started by Chris_Waddle, 11 Sep 2009.
  1. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    I'm hoping that some of you might be able to help me with a problem I have with this pump.
    I am currently in the process or re-building my pc and want to set up two watercooling loops. My main loop has a Laing D5 pump and that works great; cooling the CPU & Chipset.
    I've decided to put the graphics card on it's own loop. I have a oldish DDC pump that I thought was broken. I took it apart gave it a bit of a clean up, set up a loop from the pump to a reservoir and back again. I plugged it in and nothing happened. I gave it the universal fix all method (ie. hit it with a screwdriver) and amazingly it started working.
    I was obviously delighted. I cut the power then switched it back on. It started back up. I did this a few more times and then it failed to start up again. Another few taps from the screwdriver and it started working again.
    As it's failing to start everytime I therefore can't use it.
    I am wondering if any of you can help me figure out a way to get the pump working every time?
    Any help would be much appreciated.
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    It sounds like its just a loose connection in the pump mate. Just try make sure everything is solid and immovable.
  3. grritsshawn
    grritsshawn I'm not insane I'm a modder
    20 Apr 2009
    or just keep a screwdriver handy....or just do wat i do to my phone when it doesnt work...throw it at the wall.....i call it the old american try lol
  4. Chris_Waddle
    26 Mar 2009
    Cheers for the thoughts.
    Doesn't matter now. Last night I thought that I'd get it started and leave it running for a few hours. I hoped that it might free up the motor a bit. It only helped in deciding what to do.
    After about an hour I noticed a rather nasty smell in the room I was testing it in. After a quick check it was obvious thet the pump had burnt out. It must have locked up whilst running.
    Oh well, time for a shiney new one.
  5. Frohicky1
    Frohicky1 Awaits his moosey fate . . .
    16 Apr 2009
    shiny is good :thumb:
