im starting my database coursework for my gcses and theres something i cant do. It shouldn't be too complicated: i just want to enlarge a yes/no tick box in one of my forms. When i try expanding it as i would with other things - the same way in which you resize windows - it just enlarges the area that the object takes up but the tick box is still the same size. Appreciate any help Thanks
Hmm... well in my experience thus far, access is pretty crap software, but AFAIK there's no way that you can change the size of tick boxes in any software. Every tickbox I've seen in the last... umm... whever I started using GUIs (win3.11 if not earlier) has had the same size box, at least relative to the resolution. Maybe increasing the font size would do it, but I severely doubt it.
