Memory help with bios flashing
Discussion in 'Tech Support' started by lilgoth89, 13 Jul 2014.
  1. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    well after buying a new motherboard and cpu off the forums i found they dont play well together, the motherboard doesnt support the CPU untill i flash its bios, fortunatly its an ASUS with the EZflash, unfortuantly i dont have a cpu that it does support to flash it with
    the motherboard is a 1155 Asus Maximus IV Gene with bios revision 0402 and my cpu is the I3 2125 ( i need revision 0403 to support it )
    anyone lend a cpu / advice ?
  2. GeorgeK
    18 Sep 2010
    You will need a SB chip unfortunately to flash the BIOS. Some Asus boards do have the capability of flashing the BIOS without a CPU installed but that board doesn't... I don't have one to lend unfortunately...
    Oh, and glad to hear that the CPU arrived safe and sound :|
