Build Advice Help with component choices
Discussion in 'Hardware' started by Jake232, 23 Jul 2010.
  1. Jake232
    Jake232 What's a Dremel?
    23 Jul 2010
    Hi, first time PC Builder here.
    Budget: £650 (not even £651)
    Main uses of intended build: Gaming, Design (Photoshop, Flash etc) No 3D design / rendering needed.
    Parts required: Quad Core processor, Decent Graphics Card ( maybe GTX 460?)
    Previous build information (list details of parts): Not Relevant, its dead.
    Monitor resolution: Probably 1680 x 1050
    Storage requirements: only 500GB SATA
    :read:
    will you be overclocking: no
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): Must have Xfire / SLI.
    Extra information about desired system: the £650 only has to include the desktop, no monitor or keyboard/mouse.
  2. registeredlandmine
    registeredlandmine What's a bit-tech?
    19 Jul 2010
    I'm in the same situation, think i'm gunna go for this but probabily the i5 760.
    Comes in at under £650 with free shipping (need 20 posts on this forum)
    Woops no dvd drive (add £15) perhaps a slightly cheaper psu and xigmatek asgard instead of antec 300.
    Didn't include Os either because it wasn't stated you need one.
    Just did a editted build.
  3. adam_bagpuss
    24 Apr 2009
    drop the case to a coolermaster 335 £30 from scan.
    drop the mobo to a UD2 instead of UD5
    that will shave a few pounds off
    however if you need a complete build including monitor i5 -750 is above your budget and you should probly be looking at maybe at an AMD build
    try the affordable allround on bit-tech but upgrade the GPU and add the monitor and if the budget allows drop in a phenom X4 too
    why do you nede SLI since its very premium feature and your on a tight budget ? SLI IMO has always been a waste of money as performance varies too much and getting a 2nd card later is worse than buying a single better GPU later
  4. registeredlandmine
    19 Jul 2010
    He said he wants sli, ud2 drops the pci-e ports to x4 which makes sli almost pointless where as the ud5 does it at x8.
    He says he doesn't need a monitor.
    My second build costs £644.98 so you could upgrade the case to a cm elite series. The AMD route is also worth considering, being a bit cheaper, and the am3 socket will allow you to upgrade to the new processors out next year that afaik are going to be am3 rev 2 socket not sure if that's confirmed yet.
  5. adam_bagpuss
    24 Apr 2009
    lol doh missed that last line
    yeah for £650 go i5-750
    but point still stands about SLI
  6. registeredlandmine
    19 Jul 2010
    I agree with you on sli, and its the same matter for crossfirex.
    When buying a pc you should buy a single graphics card that does what you want not two. If you plan on doing it as a upgrade route later on, its probabily not going to be worth it and you'd be better off sticking it on ebay and getting a new card altogether imo. This is in regard to gaming pc's btw. Folding machines might be worth it i don't know much about them.
  7. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    If gaming, why is an i5 needed? An i3 will do fine and save you a few quid.
  8. registeredlandmine
    19 Jul 2010
    It doesn't have to be it just can be, because it fits in his budget. It's down to him if he wants to save a bit of money.
