Hi guys, im planning a revamp of my current system, im planning to create a new theme: minimalistic with only colors: silver, white, and black Ive decided on the lian li pcV1000BPlusII for my case, however, i need matching fans. I need fans with black outer shells and white fan blades and preferably under 15 dollars a piece, Everything for my new build will be sleeved black and all cables as hidden as possible just for the hell of it, a parts list: LianLi PcV1000 BPlusII Corsair HX520 Sunbeam CoreContactFreezer(this hsf beat the TRUE!) 3xWhite fans And miscellenios items such as these clips for cable management ps: pic is from worklog of MurderBox by CharlesH on xtremesystems
Doesn't Nexus make some very nice fans with a black frame and white blades? Think I've seen Sharkoon ones like that as well.
120mm http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=49&products_id=3970 http://www.endpcnoise.com/cgi-bin/e/std/sku=nexus120mm_bw.html http://www.jab-tech.com/product.php?productid=3857 92mm http://www.endpcnoise.com/cgi-bin/e/std/sku=nexus92mm.html http://www.jab-tech.com/Nexus-92mm-...nd-White-with-Silicon-Fan-mounts-pr-3858.html 80mm http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=37&products_id=22164 http://www.endpcnoise.com/cgi-bin/e/std/sku=nexus80mm.html http://www.jab-tech.com/Nexus-80mm-...nd-White-with-Silicon-Fan-mounts-pr-3859.html Hope that helps. These fans are really quiet, and can be undervolted, and controlled very well. Good luck!
