Other Help with fault PLEASEEEE!!
Discussion in 'Tech Support' started by Arnsider1025, 13 Nov 2011.
  1. Arnsider1025
    Arnsider1025 What's a Dremel?
    22 Sep 2010
    Am posting here because you guys are the font of all knowledge! I built a rig for my kids in March, bits sourced from Scan and Ebuyer. Rig is:
    GIGABYTE H55M-UD2H
    Intel i3 530 no overclocking ,stock cooler, temps good
    4GB Corsair Dominator DDR3 1600
    1GB XFX 5770 GPU
    Samsung 500GB Spinpoint F3
    Win 7 Home Premium
    Old 19" monitor
    Ok here goes.....system was fine until today. When the start button is pressed PC powers up and sounds normal. All fans ok, GPU fan ok, LED's on motherboard on etc. Monitor has power as light is on and screen menu available BUT I see nothing on screen. No POST messages no BIOS no screenflash...monitor just stays blank. I can only think could be broken DVI cable but why would this happen when PC not moved?! I will try different monitor and cable tomorrow. I have tried plugging the DVI cable into the motherboard outlet instead of the 5770 but still the same.
    ANY IDEAS or advice gratefully received
    Cheers guys:confused:
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Easiest thing to do is pop the BIOS battery out and leave it alone for a while. Only problem is you'd need to put all the settings back in once it's forgotten everything. Of course this might not even be the problem but it's what I'd try first.
  3. Arnsider1025
    22 Sep 2010
    Thanks Blogins. I did actually have a prod at the battery but didn't remove it. What settings will it affect?
  4. Blogins
    3 Aug 2010
    Usually everything! I did this myself today but I had the chance to take pictures of my BIOS settings before hand so it was easy to adjust them back to how they were before. Even the time in Windows had to be reset.
  5. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    It will resort to default settings for everything. I'm not 100% sure, but I'm pretty sure.
    EDIT: Ninja'd, lol.
  6. Arnsider1025
    22 Sep 2010
    Cheers guys will give it a go and let you know how I get on
  7. gerardmcmanus
    gerardmcmanus What's a Dremel?
    11 Oct 2011
    have you cut the power to the machine first, pulled the plug out the wall etc. The reason I ask is because I had a problem with one of my machines not wakening up when put into sleep, when hitting the reset switch I was getting the same problem you have been getting. I didn't actually find the fault, I found when I unplugged the machine, it booted up fine, then I just switched off the 'go to sleep after.....mins' setting.
    Someone else might be able to elaborate more on this, but its worth checking before pulling bits out the machine. Could still be caused by the software, and not necessarily the hardware before its not posting. If you have another machine, might be worth swapping drives first, just to see if it boots.
  8. towelie
    towelie How do I Internet!!
    1 Sep 2011
    I see this problem all the time often you can hear the beep to say i finished posting and even the xp login.As Blogins mentions clearing the CMOS is usally the solution.
  9. bulldogjeff
    2 Mar 2010
    Remember to take the mains plug out other wise it won't reset.
  10. Arnsider1025
    22 Sep 2010
    Thanks to ALL replies. Took the CMOS battery out and left it overnight ( removed mains cable anyway prior to removing battery) replaced said battery tonight and hey presto! All booted as normal...few updates needed but seems fine.
    THANKS ALL!!
    Maybe this post may help one or two others....cheers again guys :)
