Graphics Help with Geforce 4 tv out
Discussion in 'Hardware' started by jamescdumbarton, 25 May 2004.
  1. jamescdumbarton
    jamescdumbarton What's a Dremel?
    25 May 2004
    Hi,
    I'm using a Nvidia GeForce 4 Fx5200 with TV out. I have connected the tv up properly and set up the N-view display to have a tv as second display connected using s-video.
    I have noticed that when in the display properties -> advanced it is listed as a "Default monitor and NVIDIA....." and under the monitor tab it is shown as a Default monitor...should this not say something about being a TV?
    There is absolutly nothing showing on tv, it does not even detect a signal from computer :waah:
    If anyone could help it would be much appreciated
    Thanks
    James
  2. rio2
    rio2 What's a Dremel?
    8 Apr 2004
    turn off your pc turn off your tv connect a cable turn on tv and turn on pc if you have a nvidia driver tv-out is ok.don't use a default driver of xp.by:D:D:D
  3. Guest-16
    Guest-16 Guest
    Try composite RCA instead of Svideo, or get a SCART adapter which worked for me.
  4. rio2
    8 Apr 2004
    if the video card don't check a tv connect don't ability tv-out.:D:D:D
