Notebooks Help with laptop ideas
Discussion in 'Hardware' started by DMU_Matt, 15 Sep 2013.
  1. DMU_Matt
    DMU_Matt mmmm cheesy
    23 Oct 2009
    Oh wise Bit-Tech community I seek guidance.
    My gf has a crappy old laptop that is a bout to give up the ghost, needless to say she wants a new one.
    Her requirements:
    - Lightweight and portable (she will be taking it to and from lectures and on the train)
    - DVD drive (annoyingly hard to get both this and lightweight :wallbash:)
    - Reasonable spec, doesn't have to play games or anything, just not an over-priced paperweight ;)
    Budget:
    up to ~£600
    Prefer a lower price tag, but if worth the money can go up to max.
    Her use:
    Internet and office (normal stuff)
    Any and all help is greatly appreciated :D
    Thanks in advance,
    Matt
  2. DMU_Matt
    23 Oct 2009
    80 views and no one has anything to say at all? That's kinda shocking guys........
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
  4. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    Look at the Sony Vaio Fit and Fit E.
    Also it sounds like the type of laptop you are looking for is whats called a subnotebook.
    http://notebookcheck.net for reviews.
  5. DMU_Matt
    23 Oct 2009
    Ok, thanks for the help guys. Will check them out :)
  6. Guinevere
    Guinevere Mega Mom
    8 May 2010
    If size and weight is key then have you considered looking at used Macbook Airs? You should be able to pick up something very nice for under £600 and third party USB drives are available for under <£20.
    The airs are low spec but enough for (normal stuff) and have awesome battery life. Nothing comes close to them on the spec / size / weight / battery life / resale value combination.
    Just a thought...
  7. Ganiy
    Ganiy What's a Dremel?
    8 Aug 2013
