Modding help with modding a dual 1.8 G5 mac
Discussion in 'Modding' started by wheely, 15 Oct 2009.
  1. wheely
    wheely What's a Dremel?
    15 Oct 2009
    hi guys, im new here.
    ive been reading thru some of the mod posts for G5 and very impressive.
    I have an old dual 1.8ghz G5 (3gb ram, 1 TB HD)
    I make music and would really like to make it faster and handle more precessing, and also to run Snow Leopard.
    I emailed a few mac people and they all said i can not fit an Intel Xenon logic board, and bassically i cant really vamp my old machine up at all.
    Is this true?
    If not, what could i do to make this machine top spec?
    Thanks for any suggestions.
  2. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    It is true, you can't put Xeons in your current machine.
    You could buy a complete new Intel system and mod your current case so that it can fit inside - but you can't install Snow Leopard on it, or at least not in a legal way. I think Hackintosh might be more trouble than it is worth, so you'd be looking at a windows machine.
    So the only way to make your machine top spec running Snow Leopard would be www.apple.com . Sorry.
  3. wheely
    15 Oct 2009
    really? ok, so what if no snow leaopard, just faster and more powerfull.
    what could i do?
    thanks for ur reply.
  4. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    As far as Macs go, you can only really add RAM and more hard drives. To be honest you'd be better just building a new PC for the amount it'd probably cost, and you'd get a much faster machine if you bought a new one or built a PC (especially as I'm pretty sure you can only expand to 4Gb on your mac)
    Just for reference, a 500Gb hard drive is £120 (640Gb for £160, and 1Tb for £240) and 4Gb of compatible RAM will be another £100, but both will give you a minimal increase in speed, especially as with music creation, processor speed/cache is more important
  5. Von Lazuli
    Von Lazuli I get by fine with a jig-saw.
    23 Oct 2008
    £240 for a 1TB harddrive!? In this day and age? Surely there are laws against that?
    What is so special about an Apple hard drive anyway?
  6. jhanlon303
    7 Sep 2006
  7. identikit
    identikit Minimodder
    5 Jun 2004
    OP how many DIMM slots does it have? 4 or 8?
    Also I was under the impression those G5s would accept regular SATA hard drives. Hmmm. If not you could still always get a PCI-X RAID card and do some modding :dremel:
  8. wheely
    15 Oct 2009
    ye accept any sata drive, and sdram is usual.
    so the answer is no then, theres nothing to chip, change, replace that will beef it up.
    why cant i buy a Xenon logic board and fit it?
  9. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Nothing. They use regular sata drives. I've got the dual 2.5Ghz macpro running in my basement as a media server. It has two 1Tb sata drives and a 500Gb pata drive as the system disk. Didn't need the optical drive.
    @OP, like all the other guys are saying, it would be cheaper to just get a new system than to try to upgrade this one. 10.5 is as high of an os you'll get on it. 10.6 has no power pc support.
  10. wheely
    15 Oct 2009
    @Aterius Gmork
    so i could get an intel logic board and fit with a bit of modding..?
    im running 10.4 on it now, cause its stable and uses less resources. ( i think)
    got 10.6 on the mac mini
  11. wheely
    15 Oct 2009
    @Aterius Gmork
    so i could buy an intel board and fit it, with some modding?
    sata drives work and ram is standard too.
    running 10.4.11
    10.6 on mac mini.
  12. barry99705
    20 Apr 2008
    A lot of modding, and a new power supply. Just look at any of the G5 conversion threads here on the forums. By the time you're done you might as well just buy a new computer.
  13. frojoe
    frojoe What's a Dremel?
    17 Dec 2008
    Hackintosh might be your best bet. You can build a very fast pc, then with this bootloader, install a full version of osx with no hacking. Save tons of money over a mac pro, and you still get osx. There's a great episode of the video podcast tekzilla that has all the details titled "Hackintosh Desktop Build" Its an option to consider, and its what my current scratch build will end up running. OSX without the "apple tax".
    Edit: just a heads up to anyone considering this route, there is a list of supported hardware, and it will only work with what is supported.
  14. wheely
    15 Oct 2009
    cheers guys ill check it out..
    maybe the pc hackintosh way will work..
    i dont want to spend 1800 pounds on another mac.
    id pay 5-600 to rebuild or mod my old one, but not a new one..
    cheers again.
  15. wheely
    15 Oct 2009
    sorry to be a pain, but i couldnt find anything under g5 conversion, could u kindly, post some links for this information. thanks.
  16. Fisher.
    Fisher. partially impartial
    21 Jan 2009
