Networks Help with Network setup
Discussion in 'Hardware' started by happyhammer7, 2 May 2013.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    I have a Netgear DG834 modem and a Asus RT-N16 router (running tomato firmware).
    Anway, I want to completely disable the router functionality on the Netgear, so the Asus is basically doing all the work.
    I found a way to put the Netgear in Bridge mode, which immediately loses internet connection. I then go into the Asus router and enter the PPPoE settings (plusnet login details )
    However, I simply cannot establish a connection when the Netgear is running in modem only mode.
    Anyone know anything re. what I am trying to do to lend me helping hand?
  2. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Wrong ethernet port being used on the Netgear?
  3. narwen
    narwen narwen
    6 Aug 2010
    have unchecked, isp requires login and use router for dhcp server in the netgear
  4. Atomic
    Atomic Gerwaff
    6 May 2002
  5. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    What exactly are you trying to achieve?
    Use the Netgear as a Modem and the ASUS as a router?
    Use the ASUS as a Modem Router and the Netgear as a Switch or Access Point?
  6. Ivoryspike
    Ivoryspike Air Cooled
    11 Jan 2010
    Think you're getting the bridge mode mixed up with modem only mode.
    You shouldn't be using the Asus to connect to the internet, but as a DHCP server.
    Netgear - modem mode - keeps internet settings - should knock off DHCP, check.
    Asus - Should just be used as wireless & DHCP.
  7. happyhammer7
    19 Oct 2009
    I put the Netgear into "modem only" mode. I want to use the Netgear as just the modem and the Asus as the router.
    I went into the hidden config page on the Netgear modem to change it to modem only.
  8. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Well this is what I did with my Virgin media hub and Cisco 4200:
    Media hub in modem mode using standard firmware then connected the Cisco router to the "PORT 1" Ethernet port => Internet port on the Cisco router and that works great.
    Any one using the Cisco routers new firmware that the new "Internet" firmware requires a working Internet connection to make changes to setting on your router. Other then that it works quite well.
  9. happyhammer7
    19 Oct 2009
    Got it sorted in the end. Very happy with my new router now :p
  10. ferret141
    18 Oct 2010
    What was it?
  11. happyhammer7
    19 Oct 2009
    I tried a different firmware of Tomato and Voila.
    Strange but true.
