help with pc specs
Discussion in 'Hardware' started by ajjs79, 16 Sep 2006.
  1. ajjs79
    ajjs79 What's a Dremel?
    22 Jun 2003
    Hi Guys
    What do you think of the following spec? Look to have ago at HL2 etc going to be using this for PS, Dreamweaver, browsing, running some services and light gaming any opinions? :D
    AMD Athlon 64 X2 3800 Dual-Core (Socket 939) OEM
    Kingston Value Ram 1GB 533MHz DDR2 Non-ECC CL4 DIMM x2
    Seagate ST3250820AS 250GB 7200RPM SATA300 8MB Cache - OEM
    ASUS A8N-SLI Premium skt939 nForce4 Gigabit Ethernet Firewire 8channel
    Point Of View 7600GT 256mb DDR3 PCI-E
    Gigabyte Black/Silver Micro Tower Case With 300W PSU or similiar
    Antec NEO HE430GB 430W Modular PSU With 80mm Low Speed/noise Fan
    Pioneer DVR-111BK 16x DVD±RW/RAM Dual Layer Internal IDE (Black) - OEM
    Samsung Electronics 205BW 20" 6ms 700:1 (1400x1050) Tco03 Silver
  2. Guest-16
    Guest-16 Guest
    socket 939 wont work with DDR2. You'll need an AM2 chip and AM2 mobo.
    300W is too low, go for a 450ish.
  3. ajjs79
    22 Jun 2003
    Is it worth upgrading to am2 and ddr2?
  4. DarkReaper
    DarkReaper Alignment: Sarcastic Good
    9 Jan 2004
    Well AM3 will use the same socket as AM2 apparently so that's a lot of future-proofing right there...
  5. ajjs79
    22 Jun 2003
    Chaging specs to
    Asus M2N-E Socket AM2 NF570ULTRA Audio Lan USB2 2000FSB SATA ATX Athlon 64 3800 box 2.4GHz AM2 940 pin
    Kingston Value Ram 533MHz DDR2 Non-ECC CL4 DIMM (Kit of 2)
    Any opinions on the above?
  6. Guest-16
    Guest-16 Guest
    Im not a huge fan of the 570SLI but I havent used the ultra. Couldnt say tbh.
  7. ajjs79
    22 Jun 2003
    What board would you reccomend?
