Development Help with php
Discussion in 'Software' started by DeX, 23 Feb 2003.
  1. DeX
    DeX Mube Codder
    22 Jul 2002
    I've just installed php with IIS but whenever I point to a php file the browser does not recognise the <?php ?> tags and displays the file as if it were an html file. What on earth could be causing this? I have the php file in wwwroot folder and this is where I've stored php files before but it simply doesn't work this time :(. What can I do?
  2. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    A few questions.
    I assume you're saving as '***.php'? (as opposed to putting php in ***.html files)
    Are you pointing the browser in the fashion 'C:/inetpub/wwwroot/***.php' (which wont work) or 'localhost/***.php' (which will)?
    Did you install php or IIS first?
  3. DeX
    DeX Mube Codder
    22 Jul 2002
    1. Yep. They are .php files
    2. Yep, the latter I've done it before and it worked.
    3. IIS then php.
  4. RTT
    RTT #parp
    12 Mar 2001
  5. DeX
    DeX Mube Codder
    22 Jul 2002
    Woot, I found the info I was looking for!
    Cheers RTT :clap:
  6. RTT
    RTT #parp
    12 Mar 2001
