Help with PSU
Discussion in 'Hardware' started by SaII, 7 Jun 2006.
  1. SaII
    SaII What's a Dremel?
    7 Jun 2006
    Hi all, I'm building a PC that will satisfy my gaming needs and to do school work on. As of right now I'm having trouble deciding on a power supply. :confused:
    Right now my hardwares are:
    ABIT KN8 SLI Socket 939 Motherboard
    eVGA Geforce 7600GT 256MB Video Card
    AMD Athlon 64 3700+ San Diego CPU
    CORSAIR 1GB RAM (in addition to that I'll be getting 2x 512MB from a friend)
    SAMSUNG 250GB 7200 RPM SATA 3.0Gb/s HDD
    NEC 16X DVD±R DVD Burner
    And the power supplies I'm trying to decide on are
    Enermax
    Aspire
    Thermaltake
    all are around 500W, thanks for the help
  2. specofdust
    specofdust Banned
    26 Feb 2005
    Get an Antec, Enermax, or Seasonic. 'nuff said. Also, a good 330W could probably manage that system assuming you don't have more then 1 hard disk. a 400W could definately do it, so long as it's a decent one.
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    A Tagan 420w would suit your needs fine. Not to mention it'll better than those 3 by far.
    If not Tagan, look into Seasonic. You don't need 500w though, more like 380w~.
    But always buy the better brands.
  4. specofdust
    specofdust Banned
    26 Feb 2005
    Tagan are rare and expensive in the US Shadowed Fury, which is obviously the reason I missed them out ;)
    Seriously though, they cost too much over there to be justifiable.
  5. SaII
    7 Jun 2006
    So what are the better brands? :confused:
    I live in the US so i can't get my hands on Euro stuff
  6. Shadowed_fury
    21 Nov 2003
    tagan/seasonic/antec/enermax/hiper/ocz/
    all good stuff :p
  7. SaII
    7 Jun 2006
    Thanks for the fast reply ^^
    I think I'll look around more
    Edit: What does Dual + 12v mean
  8. Mister_Tad
    27 Dec 2002
    Fortron is another one that is a bit more availible in the states than some of the others mentioned (though tagan and hiper psus are availible from newegg)
  9. SaII
    7 Jun 2006
    I just searched Newegg and tagan is not available
  10. Mister_Tad
    27 Dec 2002
  11. SaII
    7 Jun 2006
    oo Thanks for the help
  12. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    Seasonic are raking in the Editors Choce awards at the moment. Very efficient with oodles of extra power on demand.
  13. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    I had a fairly similar system to that and am running it all on the 400W version of the enermax liberty without any problems at all. I've got an overclocked dual core in there now and its still perfectly happy and is still damn quiet, the fan only spins up under gaming load and even then its still quiet. I've been nothing but impressed with it :)
  14. SaII
    7 Jun 2006
    Thanks for the great info, now i can save some money instead of buying more power than i need :clap:
  15. jakeiswicked
    jakeiswicked What's a Dremel?
    17 Oct 2005
    Fair enough saving money but id get the Hiper 580w as its cheap for its wattage, quiet, stable and will last alot longer if you upgrade your rig, of course if you dont intend to for ages then theres no point
