Hey all, I got a pre-modded case with windows, and they are mounted with screws. These screws look sorta like very small wood screws, but they are gold colored, and I want black ones to match the rest of the case. I was wondering if anyone knew of any sites (US) that have a large selection of screws in different colors. Also, the case has plastic screws on the front to hold on the clear acrylic front panel, is there a certain type of paint I need/should use on those so that it will look good? Thanks
welcome to the forums as far as the plastic bits go, your best bet is to use vinyl dye, which you can get at most automotive stores near the spray paints... if you're from california or new york city, you'll likely have to get someone over the age of 18 to purchase it for you if you're not yourself. as for the screws... you could replace them with nuts & bolts of the same size which you can probably get some help finding at a local hardware store... hope that helps
