Electronics Help with thermistor controlled fan
Discussion in 'Modding' started by Risky, 10 Nov 2003.
  1. Risky
    Risky Modder
    10 Sep 2001
    I bough a "B-Grade" Sanyo Denki 120mm fan to find it was a 4-wire model offering rpm reading and thermall comprl. However the spec for the Thermistor is:
    and I am getting a little overwhelmed looking in farnell for an equivalent.
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    That's a bit of an odd value to find, you could try parallelling three 20k thermistors. Rapid do cheap (25p) ones with the same Beta.
    Or stick a 10k pot on it for a manual speed controller :rock:
  3. Risky
    Risky Modder
    10 Sep 2001
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's a NTC thermistor. The one you link is only 20R, not 6800R. :confused:
  5. Risky
    Risky Modder
    10 Sep 2001
  6. Risky
    Risky Modder
    10 Sep 2001
    Ok now I'm getting into this........
    The Fan spec say it will vary from 1300rpm to 2600rpm over 27.5C to 25C with that thermistor and flow above and below.
    according to the forumla:
    R2= R1/EXP(B*(1/T1+1/T2))
    For this thermistor I have R(27.5C) = 6091R and R(35C) = 4424R
    So If I pick a new temp range of say 25 to 40 I should be able to solve for the B and R required.............................
  7. Risky
    Risky Modder
    10 Sep 2001
    ....some time later......
    Ok I remembered this project and propose to get onto it. My only (and critical question is:
    Does the thermistor go between 12V and the thermistor line in or 0V and therm?
  8. Risky
    Risky Modder
    10 Sep 2001
  9. Risky
    Risky Modder
    10 Sep 2001
    Bump - any ideas. Afaik Papst V models have the themistor connected to +ve line, but those are PTC rather than NTC. Still not sure and see potential for disaster.
