Development Help with website testing please
Discussion in 'Software' started by Wolfe, 14 Feb 2004.
  1. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Essentially, i cant tell if i've got my router configured properly(its a old PC running smoothwall linux) If you can just look at
    Http://68.6.108.49/
    & tell me if its working. Ive had issues with hosting stuff recently, and i think the trouble is with my ISP. They promised me a static IP, and then later took it away, and now i think theyre blocking web hosting or something.
    And yeah, i know the web site isnt impressive. It took only about an hour and a half, and that was mostly making the images, and working out the imagemaps.
    *Edit* Html is TCP right?
  2. moose
    moose What's a Dremel?
    12 Mar 2001
    HTTP is TCP, and per default listens on port 80.
    I get a timeout error while trying to view your site.
  3. pranks7er
    pranks7er mange tout
    25 Dec 2002
    times out
  4. Wolfe
    7 Sep 2003
    I've got port 80 forwared to my server, but it doenst seem to like me. I wonder if its the webserver
    %&$@&$ I'm such an idiot. I just checked from within my network, and still can't get it. I'm looking into a beter webserver now. I dont really want to use apache, cause i've heard its a pain to configure initally. Anyone know an easy to set up web server?
  5. Wolfe
    7 Sep 2003
    Can you try now? I've got a new server running.
    Cancel that, ive got 2 NICs in my computer, and the server is on the wrong one. RRRRrrrrr :wallbash:
    *Edit* Fixed the issue, it was an improperly connected cable. Screwed everything up
  6. RTT
    RTT #parp
    12 Mar 2001
    Nothing (imo and probably also 70% of the web's oppinion) beats Apache. Manual pages are there for a reason :thumb:
  7. Wolfe
    7 Sep 2003
    Yes, unless your a chonic Lazy A$$, Much like me. :) :D :(
  8. RTT
    RTT #parp
    12 Mar 2001
    There's only about 3 things to change to make it 'work' ;)
  9. jcm44
    jcm44 What's a Dremel?
    4 Feb 2002
    i am not sure what you mean with config's apache. i am running it on my "server" and it runs just fine. if you're using windows look at www.dslwebserver.com for a step by step on how to set that stuff up.
  10. Wolfe
    7 Sep 2003
    Essentially this was just a quick project to get back into HTML, and check to see if my ISP prevents me from running a server (which i now believe is true). Because of that, i dont want to have to go through all the setup of Apache. Ive only put about 1.5 hrs into it anyways.
  11. Dimazz
    Dimazz What's a Dremel?
    8 Feb 2004
    Dosent work! What is it anyways? MOddin?
