Xbox 360 Help With Xbox 360!
Discussion in 'Gaming' started by Tibby, 4 Apr 2006.
  1. Tibby
    Tibby Back Once Again
    9 Oct 2005
    Hey guys!
    I just got my xbox 360 with GRAW, PGR3 and PDZ.
    All's great apart from getting onto live.
    It can't detect my DNS, but can detect IP and everything else.
    I tried entering it manually, but still problems.
    My setup is
    Internet Router/Modem -----> Router
    Xbox------>Router
    Xbox360------>Router
    PC-------->Router
    (Note to any idiots, only one router above)
    Anyone have any ideas?
    Cheers guys!
  2. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Which router is it? Is it relatively new as many now advertise as XBL Ready. If it's not, then you will merely need to open some ports on the sucker - unless of course you've been using the Xbox before now on it.
  3. Tibby
    9 Oct 2005
    I have been using the xbox before now on it fine.
  4. Tibby
    9 Oct 2005
    You don't think it could be because they gave me a crossover cable and I would need a straight-through do you?
    I might try my xbox cable on it.
  5. mushky
    mushky gimme snails
    24 Mar 2003
    If it can get an IP address then the cable is fine.
    What router?
    What ISP?
  6. Cheese
    Cheese Doc
    6 Oct 2001
    I think most good routers these days auto sense the cable you're using... but if yours doesn't then yes I think you should be using a straight cable.
    p.s. good point about the IP!
  7. Tibby
    9 Oct 2005
    A D-Link DSL-504
    Telewest Blueyonder Cable Broadband
  8. landi_uk
    landi_uk What's a Dremel?
    23 Mar 2002
    Have you tried DMZ'ing the XBOX360 IP address?
    I couldn't host a Tiger Woods 2006 game or join private chat channels until I DMZ'd my X-Box 360 IP address. This may be because I have 2 X-Box 360's attached to my router, but other games worked fine.
    Also have you manually tried setting public DNS servers into your network setup ?
  9. Tibby
    9 Oct 2005
    There are also other problems I am having,
    I can't access my router, I can't ping my router, I can't ping my xbox.
    Also My pc won't let me get into the network wizard so I can't setup a LAN I only have internet sharing on my router.
    I have a switch but it is pretty noisy, so I would rather wait till a last resort for that!
  10. mushky
    mushky gimme snails
    24 Mar 2003
    I used to have that router. It died after about a year. Things started playing up on it then it just wouldn't connect. Might be time for a new one buddy.
    Have you tried hard resetting it?
    Although it's strange you are having probs with your PC too. Do you have more than one computer?
  11. Tibby
    9 Oct 2005
    I have a pc down in my dad's office but that's down the garden which is quite far, and there isn't a tv down there.
  12. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    Go to http://192.168.100.1 and see if the modems DHCP server is on, if so, switch it off.
    Edit:
    Just looked at that router, its an ADSL router, and you're on cable.
    Seems to me like the router is providing the IP addresses and not the ICS on the PC you've set up to share the connection. Get the serial cable, plug it into your pc and use hyperterminal to switch off the DHCP server and all other services.
  13. themax
    themax What's a Dremel?
    2 Dec 2005
    I had the same problem when a friend used his 360 at my house. It turns out I actually had to update the firmware on my router and then it his 360 was able to connect. May wanna see if you need to update the firmware.
  14. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    I had this problem too. i have a wireless NETGEAR bridge to my router. The XBox works fine on live with it but when i plug it in to the 360, i cant access the menu to enter the WEP key for the security on the network. The router dosent talk to it as it has no key. Any help???
