I just completed my watercooling rig. The only prob is that i cant gety my processor past 1655 mhz (144 fsb). It will go faster than that but wont run stable or wont load windows. What could be causing such a low overclock. I have ample cooling. I have a giga-byte ga-7vrxp a radeon 8500 and 512 of pc2100.
As I am new to overclocking (and watercooling) could some1 post a guide or link on how to unlock my cpu??
i would say that it your ram thats stopping you from getting further. as its PC2100, its default is 133. and, if its a single, 512mb stick, then these are notorious for being poor clockers, or at least no where near as good as 256mb sticks. I run a PC2100 stick @ 155 fsb, and thats as far as it can go stable. another thing that could be your problem is a PCI card. take out all PCI cards (if this is possible for u) and then try. if this doesnt work, unlock that chip!
Have you tried increasing your vcore a little? Other than that, I would agree with Muse in that something else is holding you back, like a PCI card, Ram or other chipset!
Thxs for the quick response.... I have tryed playing with the core voltage and this yeilded little results. I dont use a pci card so it cant be that So i guess its my stick of 512 ram. Guess Ill have to unlock my cpu
my 512 stick of pc2100 gets up to 158mhz fsb so i guess im just lucky...if youre not buy yourself some pc3000 and your bound to be lucky
