HentaiBox (Update 18.02.06)
Discussion in 'Project Logs' started by DeViLoN, 30 Jan 2006.
  1. DeViLoN
    DeViLoN What's a Dremel?
    10 Jun 2003
    I have been reading this forum for quite a while now, and since i resently started to build a new case, i thought i'd put up a worklog here.
    Make comments to this project here
    First of all - I'm a Great WorkLog Contestant, and so are you...
    I would like to thank my sponsors for this project
    Stephan Wille - CEO AquaComputer - For 30% Rebate on all Watercooling Equipment
    Ivar Aasland -Aasland Design - For good price on Airbrush Art
    Tommy Karlsen - Torco & Kielland - For Steelplates
    Some of you might have heard of something in Norway called The Gathering, it's a huge LAN party held at the Olympic Arena, The Vikingship, in Hamar.
    Gathering 5000++ people for a 4 day event every easter.
    This year will be my first time there, and I felt like making me a new case for this event.
    Normal computer cases are a bit cramped for my needs, therefore i felt like making a case that was suitable for my urge for space, so i decided to make a cubic case, measuring 480x480x480mm (due to the size of A.C.Ryan's Acrylpanel)
    I came up with this in sketchup.
    *edit* changed the picture to make this log safe for work (no pron now)
    I have changed the layout for the top afterwords, but do not have any sketchup drawings for that, so you'll just have to wait and see.
    I'm going to make a aluminum frame, and cover it with 0,9mm steelplates.
    First i cut all the pieces for the frame with my crappy saw, just to find out that it didn't cut straigh, so all parts had to be adjusted with my dremel.
    After cutting all pieces, it was time to mount them together.
    I drilled 6mm holes in the aluminum square pipe, and inserted some sort of rivets with M4 threads (don't know what they are called in english)
    If you repeat this enough you'll end up with this, a base frame.
    With the base done, it was time to build the rest of the frame.
    Here's what it looked like after some more building, included with a test fit of the motherboard tray.
    Before i made the top part of the frame, i mounted the first steelplate to the bottom of the case, just to make sure the frame were perfectly square.
    With the plate in place, and frame 99.9% square i could do the rest of the frame. Well, almost, at this point i'm all out of mountingscrews, so i have to wait for the next shipment to arrive (used 100+ already)
    So, the top part is made, but not 100% mounted to the rest of the frame.
    What should i do now, can't continue with the frame until i get more screws, and more cutting discs for my dremel.
    Well, it's time to play with my hot air gun, and some acryl.
    Made the mountingbracket for my 2 DVD burners. Looks great to be the first one i ever made.
    Well, that's about all i have done so far, be shure to check back for more updates later on.
  2. DeViLoN
    10 Jun 2003
    HentaiBox
    Comment my HentaiBox project here please :)
    Link to the project here
  3. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Congrats on the first NSFW worklog that I have come (no pun intended) across! :D
  4. DivineSin
    DivineSin What's a Dremel?
    23 Apr 2004
    Uhh...is this even allowed on bit-tech?
  5. LazyBoi
    LazyBoi What's a Dremel?
    22 Dec 2005
    hentai = porn ... on bit-tech????? :worried:
  6. DivineSin
    23 Apr 2004
    I'de put some censor bars over those girls if you expect that to last much longer. :duh:
  7. DeViLoN
    10 Jun 2003
    censor bars added, not used to this in Norway, where we are allowed to watch a nipple :)
  8. Mister_Tad
    27 Dec 2002
    there are plenty of places for nipples on the internet, bit-tech isn't one of them.
    just keep the rude bits censored :thumb:
  9. Nix
    Nix What's a Dremel?
    22 Nov 2005
    looking nice so far atm man. Just wondering, have you done mods before or were you just lucky with getting the sponsors?
  10. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Yo dude, so you have posted a worklog her at last.. Good ;) saw it first on www.diskusjon.no and i have just waited that it would come here! Guys, give a **** in the porn, this is a project of first class!;D
    Keep Up The Good Work man!
  11. DeViLoN
    10 Jun 2003
    Have done some mods before, but i am good with words, just know how to ask very nice, and in the same time assure the company that this project will be shown to a lot of potensial customers.
  12. Nix
    22 Nov 2005
    You sweet talker you. My mod is on hold atm whilst i redesign it yet again.
  13. DeViLoN
    10 Jun 2003
    Done some more shopping for this case.
    Bought a second-hand 240x128 LCD, this was not planned to go into the case, but changes happen.
    here's some pictures of some of the designs i have made, all but one is my own design, the systeminfo is made by Razor from LCDStudio.com (kudos)
    This will be the third lcd in this case, the two others are CrystalFontz USB634 and AquaComputer Aquaero.
    And to end this post, here's the reason for the pause in building.
    He was born february 4. 10.29PM, my second child, first born son.
    His name is Ravn, wich is the Norwegian word for Raven.
  14. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    That display looks SWEET!
    Gratulation with your son ;)
  15. DeViLoN
    10 Jun 2003
    A big box of wonders finally arrived from AquaComputer, time to mod...
    I'll start with the MultiSwitch.
    This is what it looks like originally.
    Since i'm not going to use the original faceplate, and lights are red, i decided to change it some.
    First i removed all the original leds, and then i soldered on 16 wires (2 for each led) aprox. 20cm in length.
    Then i sleeved the cables in pairs.
    All i have to do now, is to solder on som bright blue leds to the end of the cables.They have been ordered, and are due to arrive early next week.
    I haven't been able to do to much on the case lately, due to my son beein born.
    But i have done some.
    Made the second bottom plate (the floor inside the case)
    Cutting in .9 mm steel is timeconsuming with dremel.
    Almost done with the top plate aswell, just some minor adjustments to be done. still have to cut out the hole for my water tank though.
    Well, thats all for now.
    Be sure to check back soon for another update.
  16. phinix
    phinix RIP Waynio...
    28 Apr 2006
    I cannot see your pictures...:(
  17. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
    That's because this project log is two years old.
  18. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    Holy Thread Revival, Batman!
  19. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    Indeed.
    While im here, am i the only one to notice he linked his own thread... in his own thread?
  20. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Bit-tech used to separate the Log and the Thread for comments.
