Scratch Build – In Progress HEPHÆSTUS project - Update - 13/jun - page 6
Discussion in 'Project Logs' started by Yemerich, 8 May 2008.
  1. Recoil
    Recoil What's a Dremel?
    1 May 2008
    Please...someone must hook me up with a link to where I can get some colored plexi...all I have ever found around here is clear :(. I am loving the contrast the black and pink give...looks freaking sweet man! Keep up the great work :D
  2. okapi
    okapi What's a zebra?
    4 Jan 2008
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    Olá Brasil!!! that is a nice project you are doing, how about putting some red LEDs under those acrylic sandwiches and make them react to sound, temperature or something else?
  4. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    Well it helps if i know where u live :) if it is in Sao Paulo - Brazil, i cal teel like 4 places where u can buy them in all collors, but not in all shapes. Colored acrylic are sold only in complete sheets of 2m X "something". At least in here.
    That acrylic is in fact RED. But it looks pink in the photos.
    Thanks for the kind words! :)
    Olá Portugal!!! ehehehheheh
    All the pieces containing red neon acrylic will have some sort of illumination. But not reactive to something. This will be done in the yellow part of the following picture:
    The green part is what i've done i the last post, the yellow is composed by 5 acrylic rods that will react to sound or hd activity. I am yet to decide this.
    Thanks for the words fellow "tuga"! From the fellow "brazuca"! hehehehehhe
  5. Cheapskate
    13 May 2007
    You want white, blue, or UV leds. They really make the UV glow compared to the other colors. ;)
  6. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    wow! this one's gonna be of tha chain! :D
  7. ulysses Cazuquel
    ulysses Cazuquel Sex, Casemod & Rock'N Roll!!!
    29 Apr 2006
    Na minha opinião em trabalhos de acrílico o acabamento é o que faz a diferença
    Muito trabalho e boa sorte
    Vou acompanhar toda evolução
    Viva o [​IMG]
  8. Yemerich
    15 Sep 2004
    In my experience, the UV cold cathods are the best for that glowing edge on the neon type acrylics. But i never saw a decent UV led im my life :/
    So there are some workarrounds:
    -We could use White or red Super Ultra Bright LEDS. If i use the blue ones on this red it became purple. That would be nice if the whole case would light purple, but some of the internal cold cathods are going to be bright red, so that won't work.
    -We could use simple "holes" in the chassis. Through these holes the internal cold cathods would light those parts. I have to teste that thou to see if the leaking light will suffice.
    Thanks... whatever that means :D heheheh
    Aye! the finishing touches are the most important when talking about acrylics. Thats why i am being VERY careful with it.
    Thanks friend :D
    Today i had a little drawback when testing merging diferent kinds of acrylics. Not because of the acrylic itself but because of my tools. I will buy some more material tomorrow, and as soon as i get the stuuf i will continue on the work.
    Thanks all for visiting Hephaestus Project!
  9. Cheapskate
    13 May 2007
    www.besthongkong.com :D I bought 50 of the cheapest 5mm ultrabright white LEDs. They are TOO bright.
    I was thinking you would imbed the LEDs in each part. That would have messy wiring, though. :(
    Holes work well, but the glow will have shadows in it.
    I thought the blue LEDs would make this stuff look purple too, But the UV in the blue LEDs just makes if glow a brighter red on the edges.
  10. Yemerich
    15 Sep 2004
    It worth some testing. I have some of each color but red.
    The first idea is to have the leds embed on the pieces. And to help with the messy wiring i have designed a kind of "conduit". Take a close look in this picture:
    If u look under the center main piece u will see that there's a recess under it. Hard to see in the picture, but its in there. This piece is already done, and it is the big one in this picture:
    As for the link, thanks for the tip! The site is really amzing, and i think i would buy something from them.
    Thanks for comenting too. You have always constructive ideas and alway help people :)
    I just had to say that:thumb::rock:
  11. Yemerich
    15 Sep 2004
    A nice idea.
    Yesterday I woke up with a nice idea. As the neon acrylic sheet that i ordered didn't arrived, i decided to put to work my idea.
    To use it, i had to remake one of those 4 pieces from the previous post.
    So here's what i've done step-by-step.
    As we can't find acrylic sheets with more than 10mm, i had to wel 3 8mm pieces together.
    First i cutted them...
    Then i welded them together:
    I've done that to be able to work them together.
    With that done, I used a "circle ruler" (whatever it's called in english) in the most beautiful single acrylic piece i eve saw. Unfortunatelly, it is a single daughter of a single old mom:
    Way too beautifull! :lol:
    With that "circle ruler" i've found the the center of the fiece to use the 30mm hole saw:
    Ready to be drilled:
    I had no hole saw until a week ago. Now i have 5 :D
    And this is the crude result:
    After some filling...
    And this is the result before sanding:
    Now its time to weld the acrylic rod in place:
    Sawing the excess:
    After sawing, i discovered that the piece is not quite acrylic (polycarbonate?). It is something "diferent":
    The smell (the true acrylic have no smell), the sawing dust and the texture are diferent...
    Even being sawed near the limit, the filing is imperative. After some time filing, thi is what i've got:
    As this end won't appear, i am not too concerned by its looks.
    With that done, the piece needed to be filled again to match the other that was originally from that part. Only 2 of the 3 original layers will be used:
    Yeah... all that finishing needed to be redone.
    Time to add some personality to the piece:
    Ready to be sanded and polished:
    Ela polida sem o encaixe de tras...
    Filing + sanding = torture!
    Completed:
    Second test:
    Notice that now we have 2 acrylic rods.
    Detail:
    Another detail:
    I am happy with the end result hope you like it.
    Later mates!
  12. The boy 4rm oz
    10 Apr 2008
    Mate your skill with plexi is AMAZING. Great work.
  13. Rozzy
    Rozzy I'll get there :P
    1 May 2008
    Wow i could only dream of making a case that looks this professional!!!
    Absolutely love it!!! Keep up the hard work.
  14. Yemerich
    15 Sep 2004
    Thanks :) My real skill is "patience"! heheheheh
    Thanks Rozzy.
    This was my first case ever, back in 2003:
    So, with hard work and research, everybody can make a good one :)
    Lots of work yet to be done. I really hope to get some professional look in the end :)
  15. JrRRr
    JrRRr Minecraft addict
    27 Mar 2003
    Hi! Nice build! I realy liked those end-caps with the acrylic rod, I think this smiley::jawdrop: best describes my reaction! ;)
    And I like your sence of humor, it makes reading your log just that more delightful!
    Anyways.. ..keep up the good work, I'll be folwing this log! :thumb:
  16. Yemerich
    15 Sep 2004
    Thanks JuniorRRr. I am really enjoying doing this one :)
  17. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    woah man this is some seriously awesome work!!! those end caps are so awesome like!!
  18. DXR_13KE
    14 Sep 2005
    you could put a circular led thing in that end cap... something like a circular pcp with several leds that rotate according to an external stimulus.... like the hard drive functioning, or sound. think of it like the kitt's (from knight rider) front sensor.
    similar to this:
    http://www.youtube.com/watch?v=SqK8oacCmRE
  19. Yemerich
    15 Sep 2004
    Thanks Oreon :)
    Thats a good idea, but there are some more "reacting" lights in the front:
    This one will be the hdd lights...
    ... and these ones will be DVD lights:
    I am planing to use the Kitt circuit in that one.
    Although this is the original project, i am yet to figure if it will be all like that. But that idea is really nice!
    Thanks all for visiting :)
  20. The boy 4rm oz
    10 Apr 2008
    I love the light idea.
