Storage Heres a good 'un
Discussion in 'Tech Support' started by Cerberus90, 3 Apr 2010.
  1. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    So I recently got a new HDD.
    Put it in and started reinstalling windows onto it.
    I'd got my external drive plugged in at the same time.
    Install seemed to go fine, no problems, everything seemed alright.
    Today, plugged the power in, turned off the external HDD as it was making a noise.
    Turned the PC on, went past POST, got to the little white flashing cursor thingy, and stuck.
    Restarted, same thing.
    Turned on the external drive. Boots up fine.
    In the Storage Management thing, the external drive is apparently :
    System, Active, Primary Partition
    If I try the repair function after booting from the windows disk, without the external HDD on, the box where it asks you to pick the OS to repair, there isn't an OS listed.
    So, it seems as though the install details etc went onto the external drive, or the MBR or something.
    Is it possible to get it booting properly from the correct HDD without reinstalling windows again.
    I'm not overly bothered if I have to reinstall, its just easier if I don't have to.
    Cheers.
  2. Anarki
    Anarki CULV fan
    2 Apr 2010
  3. Cerberus90
    23 Apr 2009
    might be.
    You think all I need to run is Drive:\boot\Bootsect.exe /NT60 All
  4. Cerberus90
    23 Apr 2009
    dammit.
    Just tried to boot up with the external drive on. And it won't boot now.
    If left for long enough, it comes up with the message :
    Reboot and select proper boot device
    or insert boot media in selected boot device and press a key
    Stupid computers.
    Looks like I'll have to reinstall windows now.
  5. Anarki
    Anarki CULV fan
    2 Apr 2010
    Yeah that's definitely a screwed up MBR :(
  6. Cerberus90
    23 Apr 2009
    Think I can fix it without reinstalling??
    Just tried booting into linux via CD, to see if I could edit boot.ini.
    But win7 doesn't have boot.ini does it?
    Couldn't find it anyway, and anything that looked boot related, ubuntu wouldn't open.
    I must be able to sort it if its just a mucked up MBR, surely.
  7. Cerberus90
    23 Apr 2009
    Ahh, I can run that command from the command prompt by booting from the windows disc.
    link
    dear god I hope it works, :D.
    *EDIT*
    Stupid thing!!!!!!
    Booted from my windows disc.
    But it doesn't have this bootsect.exe
    It would seem that I can't repair the MBR, because the windows disc doesn't know that theres a OS installed on the hard drive.
  8. Anarki
    Anarki CULV fan
    2 Apr 2010
    Yeah that's definitely a screwed up MBR :( Good luck though.
  9. Cerberus90
    23 Apr 2009
    Is it possible for me to use my Windows Vista disk, which is a proper OEM disk, as opposed to my windows 7 disk, which is a MSDNAA student copy (downloaded ISO and burned)?
    Are the progs the same??
  10. Cerberus90
    23 Apr 2009
    oh balls.
    I'm just going to reinstall.
    It'll be easier than trying to faff around with this stupid thing. :D
  11. Krikkit
    21 Jan 2003
    You might have a bit more luck with a Vista OEM disk, I haven't used the Win7 MSDNAA/Student ISO.
  12. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I unplugged my external hd when i installed win 7, don't know why, just wanted to make things as simple as possible for the install.
  13. Cerberus90
    23 Apr 2009
    Yeah, I had all my other drives unplugged.
    But forgot about the external one. Didn't think it would matter.
    If I tell the installer I want windows on this HDD, why the hell would it go and put the MBR on another HDD!!!
    Reinstalled yesterday, didn't take long. Should be back to where I was yesterday morning sometime today, only got a few things left to install.
