Cooling Here's an interesting TIM replacement...
Discussion in 'Hardware' started by Pete J, 8 Jun 2015.
  1. Pete J
    Pete J RIP Teelzebub
    28 Sep 2009
    I was looking for some thermal pads for an application I'm working on and came across this:
    Self-Adhesive Graphite Thermal Gap Pad
    What's to like? How about 1,600 W·m-1·k-1 and a thickness of 25 µm? From what I can see, this should destroy any TIM out there.
    Anyone care to give it a go? I would if I was setting up a new rig.
  2. wolfticket
    19 Apr 2008
    This suggests it has already been tested and the results aren't good: http://forum.notebookreview.com/thr...e-conductive-material-for-cpu-and-gpu.772906/
    My initual though before googling was that while it is very conductive there is nothing to suggest it is particularly malleable, so it probably isn't very effective at filling imperfections which is one of the most important jobs a good TIM performs.
  3. Newton Sporkfondle
    Newton Sporkfondle Spork, the all-purpose eating tool!
    30 Mar 2015
    At £25.55 inc VAT seems rather expensive for a TIM replacement that is unlikely to work well.
  4. Pete J
    28 Sep 2009
    Interesting find, though (as you no doubt realise) there's no actual performance numbers I can see.
    That's what I thought as well, though the shop page does say it is 'flexible'. I wonder if the high conductivity would make up for the potentially reduced contact area?
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    These graphite pads aren't meant as a TIM replacement, but as a replacement for heatpipes in low power applications. Basically where a copper sheet just doesn't cut it, but the bulk of a heatpipe (or vapour chamber) is overkill.
  6. atc95
    atc95 I have the upgrade bug!
    3 Dec 2012
